Thread: Unintended OCLT....
    Jul 2007
    Hillsborough, NC
    525
    Unintended OCLT....
    My pool pump and SWG Are plugged into receptacles that are controlled by a timer. I have a short whip on the timer that plugs into a heavy gauge (#10) extension cord I built a while back. I wanted to get the pool open this summer. In the fall I will pull a new outlet closer to the pool and bury some wire. I have the extension cord plugged into a GFCI outlet. This evening the pool vac didn't seem to have picked up much last night. We had rain last night, started at around 9. At about 8:30 last night the pump was running. Tonight it didn't start on time. Checking things out the GFCI had tripped. So I got at best about 45 minutes runtime on the SWG last night. I tested chlorine yesterday evening. No chlorine at all last night or all day today and it was still at the same as last night.
    27' Round Might Sun AG Pool 18000 Gallon Intex Krystal Clear SWG Hayward Pump/Filter on a Timer
    Jun 2014
    15,153
    Re: Unintended OCLT....
    Steady FC ... that's a good thing. Happy water.
