Results 1 to 13 of 13
Thread: Dirt on the bottom
    Shelley N's Avatar
    Denver, Colorado
    199
    Dirt on the bottom
    We installed our above ground pool without compacting the sand for the bottom. This will be our 4th season and I am CONSTANTLY fighting a silt problem in the nooks and cranies on the bottom. It collects in each and every dip--you can even see the different layers of sediment in some of the larger spots. Whether we just live in an incredibly dusty area or my filter isn't working on this small stuff I can't say. The sand in the filter looks perfect, no veining. I tried adding DE to my filter last year and did not notice that it helped, it just made the pool cloudy for a month or so. I'm thinking of sacrificing the 4-year old liner and compacting and smoothing the bottom and making a slight depression across the entire pool to catch this sediment so I only have to vac in one area. Has anyone fought this silt battle and won? Is there a type of automatic cleaner that works well on this problem?
    Shelley
    Denver, CO
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: Dirt on the bottom
    Everyone gets it, not much you can do about it. Try Skimmer Socks, see if that helps.
    Shelley N's Avatar
    Denver, Colorado
    199
    Really!!!? Everyone?! Do you think it's new deposits daily, or it's too small for the filter, or both? Do you think a smoother bottom would help? I know it would in my love life!
    Shelley
    Denver, CO
    pepsiholic's Avatar
    May 2009
    Fairmont, WV
    362
    I know what you're talking about. Darn those wrinkles!
    I invested this year in a pool blaster max. It was a little pricey, but it gets the job done. It runs on a rechargable battery, so I just hop in the pool, turn it on and sweep it up. I do place a skimmer sock in the pre-existing filter to catch the finer stuff.
    As a matter of fact, I just braved to cold water and swept it out today, you'd be amazed at what it picks up.
    24 x 52 Round AG Outback Empire Pool 13,500 gal.
    1 HP Hayward Power-Flo pump w/Hayward 18" 150lb. sand filter
    TF-100 test kit & SpeedStir
    Wanda the Whale Vacuum
    Shelley N's Avatar
    Denver, Colorado
    199
    That explains why I don't remember having it the first year. So filters don't catch it and I keep acquiring new amounts year after year and just blowing it around. Oh I'm so excited to get some socks! Thanks so much!
    Shelley
    Denver, CO
    pepsiholic's Avatar
    May 2009
    Fairmont, WV
    362
    Yes, socks will help, but not completely eliminate it. I run a skimmer sock 24/7 and just vacuumed a few hours ago and it's already settling back in. A lot of it is pollen I'm sure. My allergies and sinuses have been killing me, grrr!
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    we use a pool rover jr 3 days a week to pick that stuff up...it's just dust in th air settling on the bottom of your pool
    Shelley N's Avatar
    Denver, Colorado
    199
    I'm so relieved it's not my filter. Last year there was commercial construction across the street that blew fine fine clay silt all over, all summer. That's when I got most of it. $319 for a Pool Rover and $175 for the Pool Blaster. You gotta really hate dirt huh!
    Shelley
    Denver, CO
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    I do love it...honestly it's worth the $300 not having to vacum...but I picked mine up last oct at Namco for $149 during the fall closeout...refurbished, but it looked all new to me...works great
    pepsiholic's Avatar
    May 2009
    Fairmont, WV
    362
    Don't like dirt, that's for sure
    But for me it was the simplicity of not having to drag out and untangle the hoses, get it all hooked up, only to lose prime on the pump, have to go down and re-prime, go back up and hook it all up again, so on and so forth...lol
    I don't have to have the filter running when I use the pool blaster, the water is "still" and I can see everything much clearer. I just hop in, blast the tunes and sweep away.
    Shelley N's Avatar
    Denver, Colorado
    199
    What about a "slime bag"?
    Shelley
    Denver, CO
    Jun 2008
    Marana, AZ
    347
    Pool Blaster Catfish works really good on that, too. Same thing as the max, just smaller & doesn't run as long. Also less expensive. Runs long enough for my 20' diameter AGP. I put a skimmer sock in the catfish's bag. I get the desert dust, very fine stuff, and, like you, we didn't really compact the sand so our bottom is a bit "rippley". That's another reason I like the pool blaster - it doesn't care.
    Above ground soft side Omega pool
    20 feet diameter, 4 feet deep
    Hayward sand filter
    Hayward 1 HP Matrix pump
    Hayward Aquabug Automatic Pool Cleaner
    Aug 2007
    near the swamp
    806
    Sta-Rite Lil Shark, thank me later.
