Thread: Fiberglass slide plumbing help
    I just installed an older fiberglass slide on our I ground pool and hooked up the sprayer to a garden hose. I would like to hook it into my filter pump but don't know where the best place is to hook in or if the pump has somewhere I can hook into. The garden hose reduces down to a basic refrigerator line. I am using a Hayward pump. Any help is appreciated.
    mas985's Avatar
    Pleasanton, CA
    11,737
    Re: Fiberglass slide plumbing help
    Is there a pool return near the slide?
    The other option would be to cut into your return side plumbing, put in a 3-way valve and a pipe or hose to the slide.
    Mark
    Quote Originally Posted by mas985 View Post
    Yes there is a return close to the slide.
