Thread: Chloriation but cloudy water
    Jul 2016
    slidell
    58
    16000 gal gunnite pool with the following details today ( has been showering everyday for last 8 days in New Orleans area) pool details today are Alk 120, ph7.6, FC 4. Added (noon) 1 lb 73 % to pool (16K gal) and water slightly cloudy for past few hours now 6:30 pm). Will the cloudiness clear in day or so without chemicals? thanks
    Blue haven kidney style 16,000 gal gunnite including Spa, test Kit TF - 100
    Built 2000 deep end 7.5 feet, 2 steps at shallow end
    Original SWG then convert to chlorine
    Pentair Clean & Clear cartridge filter (4)
    Blue Haven Teledyne Laars Platinum II heater
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,680
    Re: Chloriation but cloudy water
    When did the cloudiness show up ??
    What is your CYA level and have you been maintaining that FC level or has it been dropping lower in the past few days preceding the cloudiness ??
    Have you tested for CC (combined chlorine) ??
    How long do you run your pump/filter per day ??
    Solar Blanket, Well Water, Borax Added. 68
    Jul 2016
    slidell
    58
    cloudiness showed up immediately after broadcasting 1 lb granular chlorine, CYA 40, has dropped a bit due 8 days of showers 9about an hour each day), have not tested CC, filter runs 10.5 hrs a day. (8:30 - 7 pm)
    Jun 2015
    Raleigh
    357
    Have you tested CH?
    18' x 38' Pool, 3' to 8' Depth
    Vinyl Liner
    SWG
    Variable Speed Pump
    Sand Filter
    Dec 2014
    Santa Ana, CA
    523
    Quote Originally Posted by 63john View Post
    Please put your test kit name into signature. Then post the following results in one go:
    FC=
    CC=
    CYA=
    pH=
    44k plaster pool, Pentair 011018 pump, DE6020 filter, LED lights, K2006 test kit
