Thread: Adding Salt to a non SWG pool
    Jul 2015
    HARRISBURG NC
    11
    I would like to improve the feel of my water. It currently feels hard and seems to pucker the skin on hands fairly quick
    How much salt would be suggested ? Or other options
    Ph-7.2
    Fc-3.5
    Cc-0
    Alk-90
    Cya-50
    Cal-200
    Salt-1.8
    Temp 91
    25 year old construction
    20x40 In vinyl 36k gal
    2 skim 3 returns
    Pentair super flow VS, Sand Filter
    TF 100 test kit
    38,521
    Re: Adding Salt to a non SWG pool
    Well, we usually suggest about 2000ppm of slat for the feel. If your 1.8 is the same as 1800ppm, then you are basically already there.
    FYI, for a CYA of 50ppm, your FC is too low. You should never let it drop below 4ppm.
    Jul 2015
    HARRISBURG NC
    11
    Jason
    Thanks for your reply. I am using aquacheck test strips for salt test. 1.8 was strip reading. = 600 ppm. I usually keep my FC at 8 ppm but i ran out of bleach.
    What about adding Borax ? or would you suggest salt ?
    Thanks Roallen61
    2 skim 3 returns
    TF 100 test kit
    Mod Squad pooldv's Avatar
    DFW, TX
    24,514
    Salt will make a bigger improvement than borate. People are salty and salt in the water makes it feel better to skin and eyes. A saltwater pool has 3500-4000 ppm salt, tears have 9000 ppm salt and the ocean has 35,000 ppm salt.
    Jul 2015
    HARRISBURG NC
    11
    Thanks, pooldv
    I added pool salt to 2660 ppm. The water feels way better and does not sting eyes.
    Thanks again for all the great advice
    2 skim 3 returns
    TF 100 test kit
    DFW, TX
    24,514
    Good deal! You're welcome.
