Thread: Jandy rs temperature sensor
    Jul 2014
    Raleigh, NC
    59
    Does anyone know is there an aftermarket temp sensor replacement for part# 7786. This is a 50' sensor for air/water/solar by Jandy? Thanks
    32,000 gallon inground plaster pool/spa combo spillover. Aqua Rite Pro with Sense and Dispense. Jandy iAquaLink Control. Polaris 280 vac. Sheer Descent, Fiber optic deck jet water feature. Vanishing wall. Whisperflo pumps, Pentair clean and clear cartridge filters.
    ps0303's Avatar
    Jul 2011
    FL
    3,695
    Re: Jandy rs temperature sensor
    I haven't seen any.
    Paul
    http://www.gastekservice.com A word of caution: When working with gas and electrical you might want to consider a licensed contractor. Consider the value of your life and others around you. If you would like to provide a review of the help I provided, please use the following link to leave a review. gastek - Google Search,
    Mod Squad pooldv's Avatar
    DFW, TX
    24,497
    I believe all temp sensors are a standard 10k ohm thermistor and you can add as much wire to it as you want. You can use a Pentair sensor. And probably any other brand.
    Edit: see post below for further information.
    May 2015
    katy, tx
    31
    I just ordered one off of Amazon. I think I searched for Pool temperature sensor or something similar. There are a bunch. The main thing is to make sure the one you order is curved to match the pipe.
    16,500 gallon in-ground pool and spa with Quartzscapes Midnight-blue and pretty sparkles
    Aqualink RS with PDA
    Jandy Pro Series Plus HP 2 HP 2 Speed Pump
    Jandy CV460 Cartridge Filter
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Pooldv, you are incorrect they tend to all be 10K sensors, but some have different curves so while they all read 10Kohms at 77 degrees F, the farther the temperature is away from that the more they may read wrong. This can be a big problem when it comes to freeze protection as it can shift the readout temperature by about 15-20 degrees one way or the other depending on which curve the individual product expects.
    Ike
    p.s. this is usually a minor issue if dealing with swim temperature measurements as the difference is only a degree or two at typical 85-90 degree swim temperatures.
