Thread: Controlling skimmer suction
    May 2015
    TN
    312
    I am wondering if I have my valves set correctly to control my skimmer flow. First of all here is my setup... My skimmers and my jets are on the same side of my pool. From what I was told, both my skimmers are on the same line. The other day I was playing around with it and had it set different than normal and both skimmers were sucking a whole lot harder than usual. I have a three position valve and if you are standing looking at it the valve is pointing towards me. From there I can go left or right. The other day I had it turned to the right I believe and it had tons more suction than usual. I turned it back because I was afraid I was hurting something, but that suction sure looked like it would skim a lot better and keep my pool cleaner.
    24k gal. In-ground, vinyl. 2005 build
    Hayward Pro-Series S244T sand filter system
    Hayward motor & pump (rpm 3450,model SP2607X10)
    Polaris 280 w/booster pump.Taylor K-2006 test kit
    Jul 2015
    Central Valley CA
    1,109
    Re: Controlling skimmer suction
    Pictures might be good, in general I wold say if the flow out of the return jets is not any slower than normal then you are not constraining the suction supply to the pump and by extension the pump is not working any harder than normal. If the result is better skimming I say go with it.
    12,300 Gallon, IG PebbleFina, 3 ft sheer, 2 Jandy nicheless LED lights, Jandy Pro 1.5HP VS pump (A.O. Smith Motor), PB4-60 Booster pump, Polaris 280, Jandy cv340 cartridge filter, Zodiac Z4 control panel W/iAquaLink, Stenner pumps for chlorine & MA connected to WiOn WiFi switches, TF-100. You can support TFP with AmazonSmile just click the link!
    Apr 2015
    tucson, arizona
    1,126
    Sounds like one side of 3-way valve is for the skimmers and other side is the main drain. If you turn it opposite of full skimming what happens? If the skimmers turn off but you still have good pressure then you are probably pulling from bottom drain
