Results 1 to 11 of 11
Thread: 2 returns don't work
    Jun 2016
    Austin, TX
    334
    New pool owner, not a new pool. I have 2 returns that happen to be the ones right under the skimmers that don't flow in my pool, the eyeballs look great, nothing weird. All other returns work as well as my polaris line. I do not have float diverters in the skimmers if that has anything to do with it. Any ideas? I am going to clean the filter in the next couple of weekends to see if pressure has anything to do with it. Thanks!
    13k Gallon IG Pebble w/ attached Spa, AquaRite T-Cell-15 SWG, Hayward DE6020 Filter, Hayward 2 HP Pump, Hayward 400k Heater, TF-100 Kit, Pool Logger
    38,463
    Re: 2 returns don't work
    Could very well be equalization lines that are just connected to 2nd hole in the bottom of the skimmer. You would need float diverters for them to actually do anything though ... the point is if the water level dropped below the skimmer, the float diverter would shut and water would be pulled from the equalization line to prevent the pump from being damaged.
    Jun 2016
    Austin, TX
    334
    Ohh so they are not regular returns?
    Jul 2015
    Central Valley CA
    1,109
    They could both be equalizer ports or one could be an auto fill if there a second lid in the vicinity that looks like a skimmer.
    12,300 Gallon, IG PebbleFina, 3 ft sheer, 2 Jandy nicheless LED lights, Jandy Pro 1.5HP VS pump (A.O. Smith Motor), PB4-60 Booster pump, Polaris 280, Jandy cv340 cartridge filter, Zodiac Z4 control panel W/iAquaLink, Stenner pumps for chlorine & MA connected to WiOn WiFi switches, TF-100. You can support TFP with AmazonSmile just click the link!
    Jun 2016
    Austin, TX
    334
    Yeah, no second lid, just the 2 skimmers. So if I got float diverters would these ports flow, or no?
    Jul 2015
    Central Valley CA
    1,109
    They would but it would be slight may not even be noticeable. When it would be noticeable is if the float closes or if the skimmer gets full, and that's the whole point you want most/all coming from the skimmer unless something goes wrong.
    Jun 2016
    Austin, TX
    334
    Got it, so I won't worry about them. Thank you very much!
    38,463
    Verify you have 2 holes in the bottom of the skimmer. Shove a garden hose in the one closest to the pool, see if you feel water entering the pool. Mystery solved
    Jun 2016
    Austin, TX
    334
    I do have 2 holes in the skimmers. I will try that. Thanks!
    Jun 2016
    Austin, TX
    334
    You are correct. The hose trick worked. They are equalization lines. Should I put float valves in?
    Jul 2015
    Central Valley CA
    1,109
    If you can imagine at situation where the water lever might drop below the level of the skimmer by accident then they are cheap insurance. For instance if you have to drain off rain water frequently and there is a possibility of forgetting about the pump running they can save your pump. When I have to drain I use the pump timer in case I get distracted.
    I would not use them to drain below the skimmer on purpose it will work but it is kind of hard on your pump better to use a submersible for that.
