Results 1 to 10 of 10
Thread: How much bleach are you adding daily?
    May 2015
    TN
    312
    How much bleach are you adding daily and how many gallons do you have? I have approx. 20k gallons and have to add around 100 ozs. per day. My CYA is 50. It seems a little exhausting. That is around 6 gallons a week. However, it is not that aggravating considering all I have to do is add bleach since my pH, TA and everything stays perfectly balanced due to the TFP method. I was just curious on what others similar to my setup are having to do.
    Also, we are having a pool party next weekend. This will be the biggest load this pool has seen. Can you give me advice on how to treat my pool before and after? Should I load it up with bleach before hand?
    24k gal. In-ground, vinyl. 2005 build
    Hayward Pro-Series S244T sand filter system
    Hayward motor & pump (rpm 3450,model SP2607X10)
    Polaris 280 w/booster pump.Taylor K-2006 test kit
    epro05's Avatar
    Jun 2014
    Keller, Texas
    274
    Re: How much bleach are you adding daily?
    This hot time of year I add one 121oz jug of 8.25% bleach everyday to my 27500 gallon pool. Sounds similar to you.
    27,500 gallon in ground gunite/plaster (1995). Attached Spa with fountain, spillway, and 2 lion heads streaming into the pool. Hayward pump and AO Smith UST1152 1.5 hp motor (single speed). Hayward 60 sq ft DE Filter (Model DE-6000). Kreepy Krauly cleaner.
    May 2015
    TN
    312
    Have you put the math to it for a year to see how much you spent compared to the traditional method? I wouldn't go back for anything, but I was curious.
    38,514
    100 oz of 8.25% bleach in your 24k pool is 2.8ppm of FC ... it is normal to require 2-4ppm of FC added daily. So, looks normal.
    Before the party, add 2-4 ppm extra FC, then test and adjust after the party.
    Dec 2014
    Santa Ana, CA
    523
    you can try to measure overnight loss to make sure nothing else is going on and consuming your chlorine. Anything above 0.5ppm over night (no sun) would be a concern.
    44k plaster pool, Pentair 011018 pump, DE6020 filter, LED lights, K2006 test kit
    May 2015
    TN
    312
    Thanks, Jason for that info! Guess it all depends on how much pee I get in there, HA!
    May 2015
    TN
    312
    When are you guys doing your testing and adding? Morning or late eve?
    Jun 2014
    Rogers, AR
    428
    I test every night around 7:30 and chlorinate shortly after.
    The last few weeks I have been adding 56 oz around 3 pm and it has been keeping the chlorine more level. It has been working well for me.
    16x32 IG rectangular 21,800k new vinyl liner 2014, Triton II TR 50 sand Filter, Pentair 3/4 hsp whisperflow pump, 3 returns, TF100 test kit w/speedstir. Maytronics s 300i robot.
    JesseSchmidt's Avatar
    Jun 2015
    Fairfield Twp, OH
    216
    This time of year with temps between 90-95, I'm using about 64oz of 12.5% per day. Lately we haven't been swimming much because my 3 year old has decided he doesn't like to swim, it's no fun. So I fight him to get him in the pool, then fight to get him out as well!
    26k Gal IG vinyl, Hayward Super 1HP, Hayward Pro Series S244T Sand Filter, TFTestkits TF-100 w/ Speedstir
    Links: TFPC for Beginners / ABCs of Pool Water Chemistry / GETTING STARTED / PoolMath / SLAM / TFTestkits / Chlorine/CYA Chart
    BobbyR's Avatar
    Jun 2013
    Toronto, Ont
    142
    I add about 2 litres (about 65oz) of 10.5% liquid chlorine every day. Pool is 25,000 gallons.
    Lagoon 40x22, Vinyl, 27,000 gal, 1HP WhisperFlo Pump, Pentair 60 gpm Sand filter, Hayward Brominator (used for chlorine pucks only when away), Rheem gas heater, Dolphin M4 Robot
    Waterfall on separate dedicated pump
