Thread: Automatic cover question
    Jul 2016
    Middletown, NY
    3
    We are almost certain that we will be putting in a Leisure pools ultimate fiberglass pool. This pool has a built in spa with walls that are the same height as the main pool walls. Is it possible to do a udermount automatic cover with this pool? The dealer in my area contracts out the automatic cover and his rep told him he thinks it can be done but that he has to look at the pool first. This isn't really possible until the pool is in the ground. An automatic cover is something I want in the pool, and I will pick another pool design without the spa if there is no way to do it.
    The Ultimate | Leisure Pools USA
    Jul 2015
    Cape May Court House, NJ
    121
    Re: Automatic cover question
    My cover is from a company called Pennco, based in Havertown, PA. As I recall, their website had a number of videos of covers on various pool configurations including irregularly shaped pools and pools with spas. Maybe that will be enough to find out if it's possible with your pool.
    That being said, it surprises me that your company's rep wouldn't be able to tell if they can design a cover based on the specs and drawings of your pool design, or even a verbal description.
    I hope you love having the auto cover as much as we do. In the spring and early summer I covered the pool every night to retain heat that had built up during sunny days and control evaporation. Now, in mid-summer, I find I'm doing the opposite: leaving it open during the night to try to cool off the water (it's been as high as 91) and keeping it closed during the day when we're not swimming to retain the chlorine. It's also handy during downpours like we had last night to keep the pool from overflowing. Good luck!
    22K 16'x40' inground fiberglass pool, Hayward Pro Series High Rate Sand filter, Hayward dual speed 2 hp Super II Pump, Hayward AquaRite SWG, Raypak 400K btu propane heater, Dolphin Supreme M400 cleaning robot, CoverPool auto cover. Also stand-alone Sundance Hawthorne 430 gallon hot tub.
    Dec 2015
    Lehi, UT
    25
    It is possible to do a cover on a pool with a spa at the end. Do you know the cover dealer or brand that the builder is working with? The most common way to do a pool with a spa is a "Pool in Pool" auto cover. This will accommodate what you are looking for. Any pool builder that knows what they are doing should be able to accommodate this. I have seen it done many times with fiberglass.
    wjr75's Avatar
    Jun 2013
    IL
    836
    We have a slightly raised side spa that has a foot and a half recessed spill over that still spills over with the cover closed. It's more for water turnover than visual. We have a separate three piece cover for the spa.
    Inground 22k gallon gunite 15x31 main pool, 15x7 wading pool/sunning deck, hot tub/with overflow (9' octagon with limestone top) & slide NSWG, Aqua Blue Pebble Sheen
    Filter dual cartridge Sta-rite 450sq/ft, TF-100 Test Kit
    Heater Raypak 2100 400k btu cupro-nickel exchanger
    Auto pool cover, Polaris 280 auto pool cleaner, Jandy AqualinkRS8 Remote Control System
