Results 1 to 8 of 8
Thread: Pump won't prime
    Jul 2015
    Windham, NH
    49
    Pump won't prime
    Need some help trying to figure out issue with pump. It was working great and had no issue priming with a really strong return. Now the pump won't prime, but the return is still really strong with a lot of air bubbles coming out of the return with the strong current. The water level doesn't seem low but adding water anyway just incase, but still not priming even after more water has been added. I tried backwashing and tried turning pump off and then on again.
    Suggestions?
    13,541k g, AG, SHarkline Heritage 24', Hydromax AC DE95 Filter, Vinyl
    mas985's Avatar
    Pleasanton, CA
    11,737
    Re: Pump won't prime
    If the pump is pushing water out the returns, then technically, it is primed. However, if you have air in the pump basket, that could just be an air leak. Check the pump lid and drain plug gaskets for cracks. Try lubing them.
    Also, while the pump is running, look inside the skimmer and see if any air is being sucked in from there.
    Mark
    Jul 2015
    Windham, NH
    49
    The skimmer is sucking water in so fast it's created a vortex with a lot of air and water going in at once. So you think it could be an air leak in the pump basket?
    Dec 2014
    Santa Ana, CA
    523
    water level in the pool still too low? Mine does that in such case.
    44k plaster pool, Pentair 011018 pump, DE6020 filter, LED lights, K2006 test kit
    mas985's Avatar
    Pleasanton, CA
    11,737
    Yes, the water level is too low.
    Mark
    Jul 2015
    Windham, NH
    49
    ok, thanks! I'll keep adding water. Appreciate your responses!
    38,284
    You could also try adding a rock or something in your skimmer to try to break up the vortex ... after adding more water of course.
    Jul 2015
    Windham, NH
    49
    Ooh, great idea! Thanks!
