Page 1 of 3 123 LastLast
Results 1 to 20 of 51
Thread: Complaint on TFPC Method
    Jun 2013
    Buffalo, NY
    80
    Hi everyone.
    I wanted to post and state that all is going very well after switching to the TFPC method full time this year. Once you get going it really is as easy as adding some chlorine every night which takes all of 35 seconds. I test my chlorine about once a week and could probably stop all together as I now know exactly what I need on a daily basis. I've spent a whopping $35 on chemicals this year compared to close to $200 at this time last year.
    My kids have consistently come home from other pools and tell me that our water is so much more clear than where they were.....that is validation enough.
    I do however have a complaint. When going underwater with goggles on, you now see absolutely every speck of dirt that is floating around in there!!!!!!!
    Thanks for all of the help.
    Intex 16 * 48 Ultra
    2650 Intex Sand Filter
    Hayward Thruwall Skimmer
    Hardplumbed in 2014
    TF100 Test Kit
    Re: Complaint on TFPC Method
    18x52 Ultra Frame with 1600 gph sand filter and intex skimmer
    38,521
    Great to hear ... although I would highly recommend you do not test less, and really should be testing more often. That is how you catch small problems before they become bigger problems.
    borjis's Avatar
    Aug 2014
    Pacific NW
    2,329
    You can add a little bit of pool grade DE to your sand filter to clear up the specs.
    I test at LEAST twice weekly, but will often need 3 to 4 tests per week if I have a lot of swimmers.
    Some days I use the taylor chlorine test that only goes to 5ppm (4 ppm is the lowest I can be without a potential problem) so
    if it reads 5 on one of those tests I know I'm good.
    Dolphin E10 Cleaning Robot.
    JoeSelf's Avatar
    Jun 2014
    Glassboro NJ
    333
    When I turn on the light at night, I can see EVERY divot and feet marks when the installer got in and out when doing the liner.
    I also see all the wrinkles from trying to break chlorine lock by dumping in bags of shock and MPS. POOL STORED.
    13700 gal, 32'x16'x54" AG oval, vinyl, Echo Canyon II, 8500 series, Narrow Yard, Safety Fence & Stair, Sta-Rite Crystal Flow T-210WF, 44 GPM, Hayward SP1580TL 1HP Pump, Aqua Luminator, Festiva wedding cake steps, March 2006, TFT-100, Speed-Stir, Sample Sizer. Avatar Credit: TJ Townsend
    Jun 2014
    15,255
    Yes, my wife was quick to point-out all of the flaws and dirt in/around our pool once it was TFP clear. What's a guy to do?
    Casey's Avatar
    SW PA
    10,457
    Sounds like a good problem to have!
    Mod Squad pooldv's Avatar
    DFW, TX
    24,514
    Welcome to the world of Pool Snobbery.
    smforte's Avatar
    Sep 2013
    Montgomery,Al
    668
    Yep, my daughter told me my pool was so sparkling it hurt her eyes and put on her sunglasses
    Montgomery, AL
    27000 16 x 36 IG, Vinyl, Grecian, Hayward Sand filter, 1 HP Pentair whisperflo motor, Aqua Genie filter not by choice, no extra jets, Dolphin s300i robotic cleaner,Taylor K 2006 test kit, speed-stir which I couldn't live without!
    CJadamec's Avatar
    Apr 2016
    Quaker Hill, CT
    1,832
    Turning the light on at night is the worst every divot in the liner and occasional leaf stands out like they were painted in neon. The spot where my ladder used to be is the worst. Oh the problems TFP has caused me.
    Chuck-
    15x30 AG, Pentair Superflo VS, 19" sand filter, TF-100 test kit
    Aqua Comfort ACT750 heat pump / 6x20 ground mount solar panel / DIY automation
    Photos of 2016 Build, Inside Your Breaker Panel, Free Copy of 2017 NEC code
    TFP is AD Free and is funded solely by member support click here to help
    May 2015
    Fort Mill, SC
    179
    +1 to the DE in the sand filter, I've been running that way for a few weeks now. I can pass the after dark pool light test no problem. Bring on the snobs! Also maybe you need to run your filter a bit longer.
    20K gallon vinyl inground pool, Hayward Pro Series sand filter, 1 HP pump, Taylor K-2006
    Jun 2013
    Buffalo, NY
    80
    Yes I am now a poolsnob all the way!!
    The dirt I was referencing is actually what gets caught on the 2 tiny wrinkles that I was unable to get out of the bottom completely, as my wife is quick to point out. Never really paid much attention to them last year but boy can you see them now.
    On a non windy day my pool looks empty. Love it.
    Intex 16 * 48 Ultra
    Hardplumbed in 2014
    TF100 Test Kit
    RyanMcC's Avatar
    Aug 2013
    NH
    214
    TFP ruins vacations.
    On our trip earlier this month we couldn't make ourselves go anywhere near the hotel pool after we got a look at it. And it was really hot out!
    "...chemistry is not an exact science" -Mario Andrada, Rio 2016 Olympics spokesman
    21' x 52" Radiant Metric Round ~10K gal AGP with Hayward S180t pump/sand filter.
    Caldera (Watkins) Martinique 340 gallon installed in basement, Bromine and ozone.
    Taylor K-2006 test kit.
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Boy, you guys hit the nail on the head with TFP problems. When the light is on at night, every dent, divot and texture is visible. The whole bottom of my pool looks like a textured series of small sand dunes. I tell people I requested that for aesthetic reasons... And don't get me started on every little spider and cricket that I can see on the bottom of the deep end. Those suckers must sink like an anchor because they never hit the skimmers!
    Isolated Spa - 345 Gallons
    PoolingAround's Avatar
    May 2016
    Katy, Texas
    213
    I'm not trying to degrade the methods used here because obviously it works for a lot of people but what about the people who are having problems? Also, having to add bleach everyday seems like a bit of a chore, no? Most non TFP methods require just throwing pucks in the dispenser and letting it do its magic (or in your case, damage.....) but I've know a lot of people who go this route and don't have any problems. I guess my question is the TFP method primarily used to saved money?
    With that said, I'm full on board trying this method as everyone seems pretty knowledgeable on this site. Hopefully I have success stories and not "HELP, why is my pool green/cloudy,etc." threads coming up soon.
    18k gallon, 20x32, salt IC20, gunite with quartz finish, raised spa with overflow, flagstone coping, moss rock waterfall, Pentair Intelliflo variable speed pump, Pentair Racer, Pentair pool pump, cartridge filter, heater, etc., acid dispenser.
    TF-100 kit for sparkling clean water.
    38,521
    Quote Originally Posted by PoolingAround View Post
    It usually saves money and also avoids problems like climbing CYA. In areas where there is no shut down for winter and there is not a lot of rain, exclusive use of tablets will not work long term due to climbing CYA.
    DFW, TX
    24,514
    The other day I went out to look at my pool and I could see both leaves on the bottom! Sigh!
    Jun 2015
    Raleigh
    357
    There's obviously an abundance of anecdotal evidence that pucks may work for their given situation. But the science is fool proof, and without water exchange, pucks will eventually raise the CYA level to an unmanageable level that the pool will need draining. That science is a given. So, I would say that if you investigate most of the anecdotal evidence, those pools that are successful using pucks fall in the categories of:
    A) Haven't had the pool long enough to where CYA has become too high
    B) Has regular water exchange due to high rainfall
    C) Is in a northern climate where their winterizing routine is lowering the water level and refilling the following spring
    So, in some cases, given the right parameters, pucks may be utilized short or long term successfully. However, when throwing a bunch of pucks into a dispenser, you are relying on complete guess work as to the decay rate and release rate of chlorine from the puck. Nothing is testing your water and insuring that you are keeping FCs at a safe level for swimming or biological sanitation. Do you want to swim in a pool like that, or one that is monitored daily and adjusted based on real science, not guesswork? There are so many variables that can affect chlorine depreciation (sun, heat, rain, organics being blown into the pool, bather load, etc.), I'd rather not chance a puck dissolving at some unknown rate to be the determination of my pool sanitation.
    Lastly, I would love a survey of these anecdotal cases, where pucks are the only thing they are buying from the pool store. I would bet money, that most puck users are buying algaecides, ph UP, ph Down, bioclears, sparkle wonders, and whatever else the pool store concocts to keep that pool semi-clear. So, you ask if cost is the primary factor. No, it's a welcomed secondary result that all we incur is the cost of ordinary bleach, baking soda and muratic acid, and only the latter two occasionally. The primary benefit is we know EXACTLY what and how much is in our pool to keep it optimally safe and sparkling clear.
    18' x 38' Pool, 3' to 8' Depth
    Vinyl Liner
    SWG
    Variable Speed Pump
    Sand Filter
    Jun 2015
    Raleigh
    357
    Quote Originally Posted by pooldv View Post
    I know....I have to go down a flight of stairs to make sure the water is still there....I hate what TFPC makes me do
    Vinyl Liner
    SWG
    Variable Speed Pump
    Sand Filter
  20. Back To Top    #20
    May 2016
    Katy, Texas
    213
    Quote Originally Posted by robertmee View Post
    Excellent post! I guess my worry is seeing all the threads here with people still having issues while using the TFP methods. I don't kit my kit till next week so I've been doing pucks and acid in the meantime (pool is only 2 and half weeks old though). So far so good but I'm hoping I don't screw anything up when I switch over.
