Thread: Owner build Fall 2016, in need of advice
    Jun 2016
    Farmington KY
    23
    Good Morning, well we are taking the plunge! Literally! After dreaming, discussing, plotting and perusing we've decided to put in an inground pool...ourselves! I've been reading a lot online and on this site, ya'll have a great site btw So we are needing some guidance. We have decided to go with a pool kit from Royal Swimming Pools, the L Shape 20x45x36. I was curious on advice for the pump and filter...and anything else anyone wants to chime in on. With most kits, you get to choose brand and size of pumps and filters so we are pretty much clueless on what to get. And I know this is a pretty big pool. We are going with standard shallow end (3'4") and diving deep end (8'). I'm also assuming we need 2 returns on the steps and 2 or 3 returns in the pool. One skimmer? Also, we have 2 choices on where to put our equipment, at the end of the pool by the deep end or about 40 feet away sitting by our wellhouse and incorporate a new structure for all of that plus some storage. Is 40 feet too far for a pump to work well? Any advice is appreciated! Looking forward to hearing from yall!
    Jun 2016
    Farmington KY
    23
    Re: Owner build Fall 2016, in need of advice
    Anyone willing to advise on pump, filter recommendations for this size of pool?
    Owner build Fall 2016, L-shape inground vinyl 20x45x36 40,000 Gallons, TF-100 kit, from Western Kentucky
    bmoreswim's Avatar
    Jul 2012
    Central MD
    3,822
    Just a comment on your depths. By standard, I'm presuming that means the cheapest choice they offer. 8' is a minimum diving depth. An extra 6" or 1' provides a little insurance if you will. And 3' 4" on the shallow end is pretty shallow. If you don't have very small kids, you might consider 3' 8" or even 4'.
    18'x38' Rectangle (3'-8 1/2' deep w/ diving board) - 27K gal. w/ gray plaster
    Hayward equipment (cartridge filter, 2-speed pump, SWCG, automation) View Our Build
    Coverstar automatic pool cover | StoneMakers concrete retaining wall and decking | Merlin SmartMesh winter safety cover
    Spring 2013 Build | Dolphin Active 20 robot cleaner | Support TFP!
    Jun 2016
    Farmington KY
    23
    The kits come in a 42" wall panel or 48" wall panel. I assumed the 42" panel was the standard size but if it's safer to add the extra few inches for the deep end then we will def'ly do the 48". Our youngest boys are 7 yo, but they grow like weeds! I would be fine with a deeper shallow end. Thanks for the advice!
    Jul 2009
    Gonzales, La
    220
    So this is an above ground pool?
    15x36 Gunite w/Diamond Brite(Bahama Breeze plaster), 3.5-6', Pentair Easytouch Automation panel, Pentair 3HP VS pump, Pentair CNC 420 filter, Pentair 5G color changing light, Polaris 360 cleaner w/booster, Pentair IC-20 SWG
    My pool build
    http://www.troublefreepool.com/threa...ales-Louisiana
