Results 1 to 15 of 15
Thread: Is it normal to be chasing chlorine every day?
    Jul 2016
    NEW STANTON, PA
    10
    Is it normal to be chasing chlorine every day? Yesterday i checked chlorine levels after topping off the pool level, first with hth test strips and followup with hth test kit (water sample,,,add drops, etc) It tested out at 1.0 on the kit and 1 on the test strips. Per the Pool Math table, I added 44 oz of clorox (8200 gal above ground pool) tested again and it tested at 4.0 ppm TC. This morning with hth strips 1 FC. So i tested it with the new, first time, Taylor 2006.... It tested at 1.0 ppm FC and 1.6 CC. So I added once again 36 oz of clorox.
    18 ft Megna Above Ground Pool, Blue Torrent S-300 sand filter w/ 1 hp pump
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: Is it normal to be chasing chlorine every day?
    Chlorine is a consumable and needs to be added daily. Either manually or via some kind of automated chlorinator. 3ppm per day is well within normal chlorine usage.
    Mr Bruce's Avatar
    Mar 2014
    Greenville, SC
    2,088
    Yes, 3ppm loss on FC is normal, however 1.6 CC is not.
    You can throw those strips away, they are useless.
    Do you have a CYA test?
    32K gallon Plaster - CircuPool SJ-55 SWG - 1hp Hayward 2 speed Super Pump - Hayward S200 Sand Filter - TF100XL/K-1766
    Test Kits - Pool Math - Chlorine/CYA/Target/Slam Chart - Support TFP
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    The 1.6 ppm CC is also a concern. CC over 0.5 typically means that your chlorine is fighting something in the pool water. What is your CYA level?
    Isolated Spa - 345 Gallons
    Jul 2016
    NEW STANTON, PA
    10
    cya=35
    Jul 2016
    NEW STANTON, PA
    10
    I don't want to start an argument /debate but if I'm getting a 1 reading with the strips and a 1 reading with the Taylor kit why are the test strips useless? I realize the test strips won't show CC levels or TC levels but isn't the FC the most important on a daily basis.
    JesseSchmidt's Avatar
    Jun 2015
    Fairfield Twp, OH
    216
    You may have a good batch of strips but the vast majority are not very accurate. Also, with your K2006, your precision is much better allowing you to know from 0.2ppm to 50.0ppm what your FC and CC levels are.
    From the CC of 1.6 and the overnight loss in chlorine, I would suggest a SLAM.
    26k Gal IG vinyl, Hayward Super 1HP, Hayward Pro Series S244T Sand Filter, TFTestkits TF-100 w/ Speedstir
    Links: TFPC for Beginners / ABCs of Pool Water Chemistry / GETTING STARTED / PoolMath / SLAM / TFTestkits / Chlorine/CYA Chart
    Feb 2014
    Central Minnesota
    5,080
    Strips are nearly worthless for two reasons. They're not very accurate and the main reason they are not worth your time is the range/resolution of the tests. Typically test strips have increments of 1, 3, 5, 10 for TC. If your CYA is 35, your FC should never be below 3 ppm for adequate sanitation. If the color is a little darker than 3 but not quite 5, what is it? If it's darker than 5 but not as dark as 10, what is it? If it's over 10, you can't test. They're absolutely terrible for CYA. Ranges for that are typically 0-30, 30-50, 50-100, 150... etc. If your CYA matches the 30 color, is it 30 or 40... or is it 50? All three would have different FC level requirements to maintain sanitation.
    jeffchap's Avatar
    Jun 2012
    Edmond OK
    1,554
    Test strips read TC, but we're interested in FC.
    25000 gallon free-form gunite
    Jandy Stealth pump/CL340 cartridge filter
    Pentair IC40 SWG
    Pentair MasterTemp 250HD heater
    Jandy AquaLink RS automation
    Jul 2016
    NEW STANTON, PA
    10
    Not to beat a dead horse, but even Taylor says in their manual, for a quick test use (their) test strips. I test every day. And if I added Clorox or something I test twice. If I was to use Taylor every time I test I would go broke buying reagent. Not to mention my pool would be all test and no swim. I have no problem agreeing the HTH strips may be inferior but just to know a range is quick and painless.
    wjr75's Avatar
    Jun 2013
    IL
    836
    The TFP test kit XL refill version for FC testing is only $16.50 for the powder and R-0871 and lasts me a season plus my hot tub through half the winter. If you feel comfortable with the test strips go for it. You don't need to test twice a day I usually test after there is no sun on the pool in the evening to add the chlorine.
    Inground 22k gallon gunite 15x31 main pool, 15x7 wading pool/sunning deck, hot tub/with overflow (9' octagon with limestone top) & slide NSWG, Aqua Blue Pebble Sheen
    Filter dual cartridge Sta-rite 450sq/ft, TF-100 Test Kit
    Heater Raypak 2100 400k btu cupro-nickel exchanger
    Auto pool cover, Polaris 280 auto pool cleaner, Jandy AqualinkRS8 Remote Control System
    May 2015
    Fort Mill, SC
    179
    Quote Originally Posted by jeffchap View Post
    FALSE, there are many 6-way strips that report both.
    I've gotten pretty good at reading the FC on my strips. Oddly, it always seems to read higher than the TC on the strip (which is a contradiction). Bottom line, the DPD reagents are the way to go.
    20K gallon vinyl inground pool, Hayward Pro Series sand filter, 1 HP pump, Taylor K-2006
    Jul 2016
    NEW STANTON, PA
    10
    Last night, I shocked my pool. This morning after making sure all the shock was dissolved I ran a test of the chlorine levels withe the Taylor K-2006. my chlorine level was still 7.2 (left over from the shock). I thought that was pretty high, so i double checked with a another (K-2006) test. I got the same numbers. So, LSS, the numbers were FC= 7.2, CC= 0.6 PH= 7.8. Now my PH is at the acceptable top and i don't wish to start chasing it so, for now, I'm hoping for rain and a weekend backwash and water add.
    Mr Bruce's Avatar
    Mar 2014
    Greenville, SC
    2,088
    When you say you "shocked" your pool, can you be more specific?
    Can you catch us up to speed on what you are trying to do, i.e. create an ongoing maintenance plan or clear a cloudy pool or ...??
    Jul 2016
    NEW STANTON, PA
    10
    yes. Thursday evening I added shock (HTH Shock & Swim) to my pool to burn out the CC because "Jesse Schmidt" above recommended "slamming" to lower my CC reading. Most of the industry call a quicker, similar, solution shocking. By shocking my CC fell to 0.6. As per my above comment my FC was 7.2 in the AM but by Friday evening it was down to 3.8. My CC was still 0.6 and my PH was still 7.8. I'm sure with all this rain my PH has dropped. But I'm not gonna burn another test till all the raining is done.
