Thread: Re: Far Skimmer stronger than near skimmer
    Triplejnj's Avatar
    May 2015
    Jackson, NJ
    35
    I have a similar setup with 2 skimmers that come into one pipe with a shut-off valve and have noticed that one skimmer always pulls stronger than the other. I have not tested it, but would it help to slightly turn the shut-off valve to partially close the stronger skimmer?
    Tom
    16k freeform IG vinyl w/ waterfall feature| Hayward 2hp pump, 300lb sand filter, 250k btu heater | AquaRite SWG | Installed October, 2014
    Jun 2014
    15,255
    If your shut-off/3-way valve is able to control the flow to each skimmer independently, it may help. For those who simply have one valve controlling one pipe that splits to the two skimmers, the diverter valve is about their only option to balance suction flow.
