Thread: Help with switching to chorine from perma salt
    Jul 2016
    New Prague
    2
    Hi, I need help with my pool. I was sold a perma salt system last year and I hate it. We put in a 27 foot above ground pool. We are on well water. When I had a small pool from Walmart, I used chlorine and now I want to go with a chlorine pool again. How do I make the change? I noticed that you suggest a good test kit. I will order a good one asap - any recommendations? I don't believe I have a lot of copper in my water, but it is a cloudy mess. I put liquid chlorine in the pool and it reacts with the metal - makes the water reddish. I cleaned it out, but now it is cloudy. I have had everything from black, red color water, slimy feeling at bottom of pool to a horrible fishy smell. So if I go with chlorine, do I turn off the copper system? How much chlorine do I need to start? How do I stablilize the chlorine?
    Thanks for helping me!! Thank you for welcoming me!
    cppanka
    I have a 27 foot x 54 in. above-ground swimming pool that holds 17,000 gallons of water. We use a standard cartridge filter system and chlorine to clean the water. We are on well water.
    Aug 2014
    Northern IL
    4,615
    Re: Help with switching to chorine from perma salt
    For now, clean out and disconnect the perma-salt system and check this out: Pool School - Test Kits Compared
    You could also add about a half gallon of regular 8.25% bleach everyday.
    More answers to follow once you get your kit!
    Jul 2016
    New Prague
    2
    Hi,
    I got my test kit awhile ago. It has taken us a long time to get most of the copper out of the pool. We have had a clear pool for about a month. No one has been in the pool because it was a mess and now it is cold. I have been using the bleach to chlorinate the water lIke you told me and have been testing the water.
    We are getting ready to close the pool, and are hoping for a better summer next year without permasalt. What I don't understand is the CYA. I tested the water, but it showed we have no CYA in the pool. We have never added it. I read up on the TFP forum about slamming the pool, but don't I have to add some CYA to the pool first.
    Thanks for your help
    Mr Bruce's Avatar
    Mar 2014
    Greenville, SC
    1,798
    How did you keep any chlorine in the pool with no CYA? How much chlorine did you add every day? What FC level did you target? This is kind of amazing.
    They sell CYA at Wal Mart, etc.
    32K gallon Plaster - 1hp Hayward 2 speed Super Pump - Hayward S200 Sand Filter - TF100XL
    Test Kits - Pool Math - Chlorine/CYA/Target/Slam Chart
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Can you add a state, territory or country to New Prague, knowing your local climate and conditions helps us give better advice
    Pool School - Read This BEFORE You Post
