Thread: CYA poblems
    Jun 2016
    Manteo north carolina
    50
    CYA poblems
    Yesterday morning my cya was at 60, tying to achieve 80. I put the 36oz according to pool calculator in a sock in front of my return. I failed to leave my pump on for 24 hours. This afternoon my cya was still 60.
    Above ground intex 24x 52 Swg with sand filter pump. Well water. New started the end of May. 11,600 gallons. Test kit TF100
    May 2015
    Land O Lakes, FL
    527
    Re: CYA poblems
    It will take a couple of days at least for the cya to fully dissolve and register in the test
    Matt
    2016 Pool Build: 12k IG Blue Granite Pebblesheen, Travertine Coping & Pavers, Pentair IntelliFlo, Intellichlor, Easytouch, Clean & Clear 320, Heliocol Solar - TF-100 test kit w/ SpeedStir
    SWG Run Time Calculator
    Jul 2014
    Hope Mills, NC
    567
    Re: CYA poblems
    Why 80?
    16 x 32 17500 gallons
    Vinyl in-ground
    Hayward 250# Sand Filter
    1 HP Pump
    Hayward SWG
    AimeeH's Avatar
    Apr 2012
    Columbia SC
    1,867
    Re: CYA poblems
    Yeah.....check that sock and give it a squeeze to agitate the granules every now and then until it's all dissolved. Then recheck CYA.
    18*36*23 true "L" vinyl IG 29,000 gallons. SWG. TF-100 test kit.
    http://tftestkits.net/splash-page.html
