Thread: Is this a reason to SLAM?
    Jun 2012
    Springtown, TX
    54
    Hey all,
    I haven't seen any evidence of algae blooms. I've been using more chlorine that usual, but have had more people in the pool too. Yesterday, the pool was 3ppm. Via the pool store, the CYA was 10 on Sunday. I couldn't get it to register on the taylor test. We added enough to bring it to 25, as that's all the CYA we had. Via pool math's calculations 16oz would bring it to 25, but it's now 40ish. I assume this fact that the CYA was higher than I thought it was, caused the problem with FC being too low. I didn't want to retest the CYA until it had been in for 2 days to give it time to come up. However, the minimum for cya of 40 is 3, so why did I have a problem to begin with?
    A few hours ago, I tested FC and the it was 0 with CC at .5 (it's rare I get a 0 reading, it's usually .5). So, I added 1/2 gal and tested again in 2 hours and it was only 2ppm and water is a tiny bit cloudy. I've added the remainder of the gallon and I'll retest in an hour.
    So, I know this is likely the beginning of algae, but without blooms or anything green, do I need to start a SLAM or just maintain the levels I should have for a CYA of 40?
    Thanks.
    AG pool is a 7,500, 200# sand filter, 2 speed pump and Taylor kit,
    Pool Tool's Avatar
    May 2014
    Western Chicago Area, IL
    757
    Re: Is this a reason to SLAM?
    Cloudy = Slam.
    Stages of algae bloom
    1. Using more FC
    2. Pool may feel slippery
    3. Start to see dust/green dust when brushing
    4. Pool looses sparkle, starts to cloud up.
    5. .... Green Monster
    Catch it early and it'll will go much quicker. Good luck.
    16' x 32' (21100 gal), vinyl, 1.5 hp Hayward SuperPump,
    Tagelus TA60/60D Sand Filter, Raypak 399K Digital Heater, TF-100
    30,426
    Time for you to SLAM. Do you have your own test kit?
    Jun 2014
    15,192
    Jun 2012
    Springtown, TX
    54
    Pat, you're awesome! ROFL! Exactly!
    Yes, I have my kit.
    Thanks all!
