Results 1 to 9 of 9
Thread: Above ground pool need help
    Jul 2016
    Norfolk
    5
    I'm a first timer on pools and need help I bought a pool that's a 16x48 and we are missing parts for the filter which I didn't know and it's all filled up the parts still haven't arrived am I able to add the chemicals now or have to wait it's also green on the bottom please help!!!!!!!!
    Jul 2016
    Norfolk
    5
    Need help !!!
    I bought a pool 16x48 filled it up and found out we are missing pieces to the filter which I'm awaiting to come in pool is green on the bottom am I able to put chemicals in now or do I have to wait??! I know nothing about pools which you can tell
    38,284
    Re: Need help !!!
    Welcome to TFP!!!
    Slowly add bleach and brush to circulate it until you can get the pump running.
    Actually, can you just hook up the pump so that the water is circulating without the filter? I am not sure what piece you are missing.
    RyanMcC's Avatar
    Aug 2013
    NH
    214
    Re: Above ground pool need help
    First and second, congratulations and welcome to TFP!
    Bummer about the missing parts, but if it's already filled then you should start by adding chemicals. Folks here way more experienced than me are going to have more specific advice, but you need to get your chemicals in there even if you don't have proper circulation yet. What chemicals are you planning on using? Do you have a test kit? What kind of pool is it?
    "...chemistry is not an exact science" -Mario Andrada, Rio 2016 Olympics spokesman
    21' x 52" Radiant Metric Round ~10K gal AGP with Hayward S180t pump/sand filter.
    Caldera (Watkins) Martinique 340 gallon installed in basement, Bromine and ozone.
    Taylor K-2006 test kit.
    Jun 2015
    Raleigh
    357
    Get some chlorine in there asap, get a test kit on the way (you'll need it), and brush and disturb the water as much as you can while you are waiting on your filter parts. The green algae will likely die and turn a milky white and once you have your filtration in place, the filter will clear your water.
    18' x 38' Pool, 3' to 8' Depth
    Vinyl Liner
    SWG
    Variable Speed Pump
    Sand Filter
    Jul 2016
    Norfolk
    5
    I have a Intex pool
    Jul 2016
    Norfolk
    5
    Quote Originally Posted by RyanMcC View Post
    It's an Intex brand pool and some one told me to but the text kit, PH up and PH down , chlorine tablets and shock which all I have bought
    jeffchap's Avatar
    Jun 2012
    Edmond OK
    1,524
    In the meantime, you should read the PoolSchool link at the top of the page to learn how we maintain our pools with inexpensive off-the-shelf items like bleach and borax instead of expensive pool store potions.
    Take the money you're going to save with our TFP method and buy an Intex sand filter and pump for that pool. I have the same pool, and the tiny cartridge filter and pump in comes with is woefully inadequate. You won't regret it.
    Also, you'll save yourself a lot of headaches and money if you'll go ahead and order a proper test kit like you'll find recommended here, either the TF-100 or the K-2006. A good test kit really is a must, or you'll be fighting that pool constantly.
    25000 gallon free-form gunite
    Jandy Stealth pump/CL340 cartridge filter
    Pentair IC40 SWG
    Pentair MasterTemp 250HD heater
    Jandy AquaLink RS automation
    Jul 2016
    Norfolk
    5
    I have a brand new sand filter and pump that came with it just missing the missing ****** so i can't hook it up
