Results 1 to 16 of 16
Thread: the correct way to add baking soda?
    Jul 2016
    Gainesville, FL
    126
    I am having a hard time raising my TA- am I supposed to add a few lbs at a time? or all at once?
    CYA=60
    FC=6
    PH=7.2-7.6
    TA=50
    Jul 2015
    Knoxville
    72
    Re: the correct way to add baking soda?
    I am by no means an expert but what I've read here in several posts is to add some retest then add more if needed, always easier to put more in than take it back outta the water lol but I'm sure some other folks here will clarify for you
    Jun 2014
    15,008
    From the TFP Pool School - Recommended Pool Chemicals page:
    Baking soda can be added by spreading it across the surface of the deep end of the pool.
    With a TA of 50, you shouldn't have to add too much right? Are you trying to sneak-up to about 60-70? As long as your pH is remaining stable, be cautious about raising the TA too much.
    Jul 2016
    Gainesville, FL
    126
    Quote Originally Posted by Texas Splash View Post
    I am trying to go up to 100, which requires 21lbs of baking soda (28k Gal pool)
    Jun 2014
    15,008
    Not sure which type of pool you have since your signature is not updated, but most pools can safely have a TA at 60-70. If you raise the TA to 100, it could easily cause your pH to rise faster each week. We always recommend satisfying the pH stabilization first, and then leave the TA where it is. But if you are still wanting to raise the TA to 100, then you can add it to the deep end no problem. Baking soda sometimes pours-out in clumps, so you may want to tap the box/bag periodically so it flows in powder form. Any clumps will sink to the bottom and can be swept around to disperse.
    borjis's Avatar
    Aug 2014
    Pacific NW
    2,316
    Is your ph already holding steady? If so, as others suggest, no need to change it. That's what its job is.
    If you do add more, use pool math to figure exactly how much and start in 1/3 increments.
    I mix anything I add (except cya & bleach) in a 1 gallon bucket of water then pour it slowly over a return.
    Dolphin E10 Cleaning Robot.
    Jul 2016
    Gainesville, FL
    126
    Quote Originally Posted by borjis View Post
    the pH keeps going up, so I was thinking raising the buffer (TA) should keep the pH from going up all the time? pool is plaster.
    borjis's Avatar
    Aug 2014
    Pacific NW
    2,316
    do you have water features?
    Jul 2016
    Gainesville, FL
    126
    no I don't
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,184
    Quote Originally Posted by archer636 View Post
    Nope, it works the opposite. The higher the TA the faster the pH change. I keep my TA at 50. As it goes any higher the pH rise moves quicker.
    Support the site
    Defgufman's Avatar
    Mar 2015
    Savannah GA
    584
    How much is it going up and at what rate i.e. Daily etc...?
    Inground 13,200 gal Vinyl, Pentair 3/4 hp pump, Pentair Sand Dollar filter, Polaris 280
    Pool School, Pool Math, CYA to FC ratio chart, Testing Kits
    Jul 2016
    Gainesville, FL
    126
    Quote Originally Posted by Defgufman View Post
    I need to add a gallon of acid weekly
    Quote Originally Posted by tim5055 View Post
    really? I thought the point of TA is to reduce pH fluctuation- this is the first place I am hearing the opposite
    http://www.poolhelp.com/handouts/oB_...%20Handout.pdf
    May 2014
    Franklin, NC
    9,184
    From the documet you linked:
    An exacerbating factor is that higher bicarbonate alkalinity can cause a more rapid upward drift in pH, due to the gradual loss of carbon dioxide from the water.
    Support the site
    Mod Squad pooldv's Avatar
    DFW, TX
    24,450
    Higher TA pushes PH up. Adding acid to lower PH will slowly lower TA until it finds equilibrium. Usually between 50 and 80. TA stops wild PH fluctuations, once TA is below 60 or 50 the PH it can swing up or down with little input. That is the part where it stabilizes PH.
    Zappafan's Avatar
    Aug 2014
    Hampton, IL.
    151
    This being my first full season after having two partial seasons, I will definitely be keeping my TA lower next year. I brought it up to 80 at the beginning of the season from the 50-60 range just because I thought it was the thing to do (reading to much here). I have decided to just "BE" the pool. Instead of using a few gallons or possibly more MA and trying to aerate to drop TA right now that I would just stay the coarse adding the little bit of MA to satisfy my testing. My pH tends to rise but not bad, just wish I had started lower and saw how it reacted.
    17K Gallon,IG Vinyl,1hp Pentair Challenger,Pentair TA60 Sand Filter, Hayward Colorlogic,Re-lined 06-20-15, TF-100,SpeedStir,Lagunitas and Margaritas. Zappafan Pool Build
    Defgufman's Avatar
    Mar 2015
    Savannah GA
    584
    A gallon a week sounds high, but your signature doesn't have any pool info in it. Since I dropped to about 50 TA last year my acid consumption is about 10 ounces a month. I also added Borates so that may make the difference too.
