Thread: New Member - Been lurking for some time
    Jul 2016
    Katy (Houston Area), TX
    4
    Howdy! Just wanted to check in as a new member. I've been lurking, reading and learning for quite some time now but just got around to signing up for an account. I live in Katy, TX which is basically a suburb of Houston. It has been at or near 100 degrees for the past few weeks now which makes keeping chemicals balanced fun, to say the least. And I just recently switched from using Cal-hypo shock and Trichlor tablets to liquid chlorine (now if I could just find somewhere to buy it less expensively...).
    Anyway, thanks for the help so far and I look forward to learning more about caring for my pool.
    Last edited by woyster99; 07-26-2016 at 11:49 AM. Reason: Revised pool chemicals used
    Jun 2014
    15,281
    Re: New Member - Been lurking for some time
    Hello and welcome to TFP!
    Jul 2016
    4
    Added signature.
    Katy, TX. In-ground free form gunite pool with pebbletec, Raised hot tub, ~20K gallons, Pentair INTELLIFLO variable speed 3HP main pump, Pentair WHISPERFLO 1 HP features pump, Pentair Easy Touch 8 Controller, Pentair CCP520 cartridge filter, Pentair MasterTemp 400 heater, Pentair LED Lights, Polaris pool cleaner, Tanning ledge with bubblers, Weeping wall.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,514
    Welcome to TFP!
