Results 1 to 7 of 7
Thread: Cloudy after pool party
    Apr 2016
    Las Vegas, NV
    48
    Cya 85, FC 10, PH 7.5, TA 100, Calcium Hardness 450
    Cleaned the filter and used a robot pool vac the day before
    in-ground pool approx 8-10,000 gallons. plaster i think.
    borjis's Avatar
    Aug 2014
    Pacific NW
    2,329
    Re: Cloudy after pool party
    You list the pool as: Plaster I think.
    was the pool ever painted?
    If so, that is the cloudiness.
    My last pool was painted plaster and anytime I had more than 2 people over it would cloud
    up from the paint rubbing off on the floor. every time I brushed it clouded up a bit, could never
    get it to go away.
    Dolphin E10 Cleaning Robot.
    Feb 2011
    Portland, OR
    51
    I have a small 10,000gl pool and it is always cloudy after a pool party. I make sure the chlorine is in the proper range after the party, put the pool cleaner in the pool and I run the pump longer than usual. The cloudiness is always gone by the next morning.
    10,000 gal Inground Fiberglass Pool;Aquarite SWG; Hayward H Series Gas Heater;
    Hayward Sand Filter; 1.5 HP Hayward Max-Flo VS Pump; Dolphin Pool Cleaner; TF100 Test Kit
    Oct 2007
    Valrico, FL
    542
    I also have the same issue. I do however use a Poly 60 algaecide which helps clarify the pool.
    7,500 gal, IG pool, L shape 22' x 15', 1.5 hp pump, cartridge filter, AquaPlus SWG/Controller, Pebble-Tec liner.
    Apr 2013
    Sacramento, CA
    2,769
    Generally pools are cloudy after parties because there is more organic matter in the pool. Chlorine will burn out some of the organic matter and the filter will filter out some of it.
    I don't really see what effect algaecide would have, though I guess it could kill some of the organic matter.
    Apr 2016
    Las Vegas, NV
    48
    Quote Originally Posted by borjis View Post
    get it to go away.
    possibly, i am not the original owner... it looks like it probably was, as there is a footprint in the shallow end
    nothing to worry about if that's the case right?
    PAGirl's Avatar
    Jun 2012
    Central PA
    2,388
    If your guests wear a lot of sunscreen or lotion the water might be a little off after the exit the pool. My family swam while I was at work. I noticed a slight haze to the water (to everyone else it likely looked great) when I got home, and realized I had forgotten to add my chlorine the night before. I then noticed a bottle of sunscreen on the patio table. I upped the FC and ran the pump and all was well a few hours later.
    If the cloudiness remains or returns, you could always run an overnight loss test to rule out organics.
