Results 1 to 11 of 11
Thread: 2 week old Hayward pump dead
    Hey guys. I have a Super flow mayrix 1hp 2 speed. Go out this morning and it's not on. Only humming noise. Brining it for warranty and ordered another pump to have as backup. Is this normal for a Hayward pump?
    Will my pool balance be OK fr a day??
    12' x 24' (21100 gal) Doughboy Desert Spring w/ Deep End, Hayward SP15922S Power-Flo Matrix Above-Ground Pump 2-Speed,
    Hayward S210T Pro Series, Hayward H100ID1 H-Series , Hayward AQ-TROL-RJ AquaTrol Salt, TF-100
    Jun 2014
    15,158
    Re: 2 week old Hayward pump dead
    Definitely not normal, but with motors ... anything can happen. Your water should be fine for one day. If it gets delayed further, you may want to slowly pour some bleach around and manually mix it as best as you can. A pump that new shouldn't be "frozen" inside from dirt or rust preventing it from turning. Perhaps it's a capacitor issue. Others may reply with detailed self-testing ideas and perhaps a good DIY repair. Good luck!
    Well Hayward is awesome
    After local authorized suppliers refused to fix as I bought it on amazon, Hayward is sending me a new pump and I can keep the old one. Time to learn how to fix it now!
    Feb 2016
    Atlanta, GA
    145
    Great news!
    Aug 2008
    Conway SC
    102
    Being a Master Electrician and when a customers ask me how long will something last, I say a minimum from the time you flip the switch to forever..
    17000 Gallons (16x32) Vinyl In Ground Pool
    Sand Filter
    Install "Finish Date" July 30 2014"
    Propane heater installed.. Used for 1 day.
    City Water.
    That's a great way to look at it!
    So here is the capacitor. Thoughts? I can get a new one for 15 bucks
    Jun 2014
    15,158
    Might be the best $15 bucks you spent on a pool repair. Hope it does the trick.
    Me too.
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    Easy and cheap fix, and you have a new spare pump to boot! Nice!
    Quote Originally Posted by Wraenking View Post
    Sent from my SM-G900V using Tapatalk
    Divin Dave,
    Stump's Avatar
    Jul 2013
    Oklahoma
    145
    Just replacing the capacitor is no guarantee motor will work. If you have a multi-meter with no power applied you can ohm motor.
    Here is an excellent link INYOpools to check motor How To Use a Multimeter to Test a Pool Pump Motor - Winding Resistance - INYOPools.com
    I hope motor is good and $15.00 is a cheap fix.
    Good Luck and be Safe.
    24' Reprieve RD/AG/13K gal Vinyl TFP method
    Waterway Clearwater 175 sqft Cartridge
    Hayward Power-Flo Matrix 1HP Pump 2-Speed
    TF-100 Test Kit SpeedStir Borate Insta Test
    Spreading TFP to All
    I do have a good meter. I'll try that. Thanks!
