Results 1 to 14 of 14
Thread: Hayward vs. Pentair THE DEBATE
    Jul 2016
    La verne ca
    4
    Hi All,
    I hear different opinions from every plumber I have give me a quote and this phase. PENTAIR VS. HAYWARD. I have heard every side of it from Pentair is built better. To Hayward has much better customer service and pentair will always give you the run around. Is there any real difference or truths to all this. System will be fully automated with iPhone remote system. Is there any real difference between Omnilogic and Easytouch? Do any of the actual pieces of equipment work better or last longer?
    Thank you all for your help as I just cannot seem to make this decision!
    Mod Squad pooldv's Avatar
    DFW, TX
    24,497
    Re: Hayward vs. Pentair THE DEBATE
    Nope. It is ford v Chevy. Dealer v dealer. There are good and bad everywhere. Your best bet is to find a great PB and buy what they sell. My PB has a great relationship with Pentair and their local distributor and has no issues with warranty claims or service calls. I'm sure the story is the same for good PB'S who use Hayward. The PB's who can't get warranty service are most often the ones who aren't good customers to begin with. I am sure that Hayward and Pentair will both go out of their way to take care of their customers.
    Mod Squad Jimrahbe's Avatar
    Jul 2014
    Bedford, TX
    7,511
    For automation, the most important thing is to use a single brand name so that everything integrates together smoothly. I concur with the Ford vs. Chevy theory as to which is the better.
    Jim R
    DFW, TX
    24,497
    Good point! Ford computers can't control Chevy engines.
    ps0303's Avatar
    Jul 2011
    FL
    3,695
    For automation I pick Pentair.
    Paul
    http://www.gastekservice.com A word of caution: When working with gas and electrical you might want to consider a licensed contractor. Consider the value of your life and others around you. If you would like to provide a review of the help I provided, please use the following link to leave a review. gastek - Google Search,
    Jan 2015
    Anthem, AZ
    188
    i prefer jandy automation over my pentair. it was just more user friendly with the iaqualink vs easytouch.
    19K IG Pebbletec with attached spa. 60sqft Cartridge filter, Intelliflow VS, 399k BTU Gas Heater, Pentair IC40. Phoenix, AZ, full sun.
    DFW, TX
    24,497
    Pentair Screen logic makes it pretty easy. It is usually folks without Screen logic who have trouble programming their automation.
    borjis's Avatar
    Aug 2014
    Pacific NW
    2,329
    Just don't pick a Hayward heater.
    Dolphin E10 Cleaning Robot.
    ps0303's Avatar
    Jul 2011
    FL
    3,695
    Quote Originally Posted by borjis View Post
    I second that. Ha ha ha.....
    Paul
    JoyfulNoise's Avatar
    May 2015
    13,213
    Quote Originally Posted by pooldv View Post
    Totally NOT true!! (You and Brian must be in league!!) I can program my EasyTouch just fine using my old school RF remote. Monochrome 3-line LCDs forever!!!!
    (Then again, I do prefer reverse-Polish notation (RPN) calculators, so that right there should be your first warning sign....)
    Matt
    May 2016
    Phoenix AZ
    128
    I have had serious problems with my Pentair pumps, Pentair heaters and Pentair SWGs. My Pentair lights, on the other hand, are the bomb.
    50,000 gallon plaster in-ground salt pool with two 60 sq ft DE filters, two Intellichlor IC60 SWGs, two Intelliflo VS pumps, two Whisperflo pumps, two Pentair 400K BTU NG heaters, PCC2000 in-floor cleaning system...two everything.
    DFW, TX
    24,497
    Wait, what? I am not even going to Google that to see if it is really a thing!
    May 2015
    13,213
    And I own a slide-rule....
    Matt
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Ah, RPN, makes me want to go grab my 48GX, I even know right where it is, complete with the hard copy manuals.
