Results 1 to 10 of 10
Thread: Solar cover falling apart
    Sep 2015
    Halfmoon/NY
    4
    I am on my 2nd solar cover in 4 years. I have a 21 ft above ground radiant pool, which gets almost all sun from 10 am to 6 pm.
    The first cover was a heavy blue solar cover. within 2-3 years the bubbles just fell right off and ended up in my sand filter.
    We then bought a replacement cover 2 years ago, this time a clear, light weight cover.
    Within the last week the bubbles are just falling off in certain spots and the seam of the cover is coming apart.
    While SWMBO was convinced it was from pulling the cover on and off the pool and rubbing up against the coping clip.
    I am of the believe that the combo of the sun and chlorine just destroys the cover.
    Is there a way to prevent this destruction?
    Is there a way to prolong the life of a solar cover?
    Or is this just the cost of owning a pool that gets full sun?
    Jul 2014
    Hope Mills, NC
    566
    Re: Solar cover falling apart
    "They all do that"
    Just noticed mine is falling apart also, if I get 3 years out of a solar cover, I think that is good.
    16 x 32 17500 gallons
    Vinyl in-ground
    Hayward 250# Sand Filter
    1 HP Pump
    Hayward SWG
    Mod Squad pooldv's Avatar
    DFW, TX
    24,450
    Yep, 2-3 years is about all they are good for. Buy thin and buy cheap. They all seem to be about the same. A few folks report a little longer life with thicker covers but it doesn't seem worth the extra cost or heavier cover to lug around.
    Apr 2014
    FOUR cORNERS
    111
    year here in the southwest!!
    16 'x 48" Metal Frame Intex 5065 gallons, 14 Inch sand filter,Hayward Skimmer SP1091LX Dynaskim, Test Kit TF-100
    Jamison04's Avatar
    Jun 2011
    Tecumseh, OK
    573
    They don't last long if not properly taken care of. Don't fold them or roll them up and just leave them exposed to the sun while swimming. They need to be in the shade or covered. A cover left all on itself in the sun will break down super fast.
    24'x52" Artesian w/ Portifino liner - Hayward 1hp powerflo matrix w/24" sand filter - AquaTrol RJ SWG. Solar heating to come. -
    RyanMcC's Avatar
    Aug 2013
    NH
    214
    Sun and chemicals aren't the best for flimsy plastic, but scraping it over the coping is worse. We roll ours up every time because it makes putting it back on a lot easier. Two side effects are that it doesn't get dragged over the coping and it doesn't get dirty. If I have to take it off on my own I'll generally just bunch it up on the coping to avoid making the horrible pile on the ground that takes forever to get back on the pool.
    Our pool gets full sun most of the day. Our first cover lasted two years just fine, then we replaced the pool. Its cover is well into its second year without showing much aging. We're not trying for longevity, though, just ease of use.
    "...chemistry is not an exact science" -Mario Andrada, Rio 2016 Olympics spokesman
    21' x 52" Radiant Metric Round ~10K gal AGP with Hayward S180t pump/sand filter.
    Caldera (Watkins) Martinique 340 gallon installed in basement, Bromine and ozone.
    Taylor K-2006 test kit.
    Sep 2015
    Halfmoon/NY
    4
    Thanks for info.
    Generally when we take the cover off we roll it & fold it up and leave it on a table on the outside of the pool. It will sit in under a peach tree and get not as much sun.
    However most times I just slightly roll up the cover and leave each end over the side to keep the cover from floating into the pool.
    I am just amazed out how quick the cover went from usable to shredding in the last week!
    21' above ground round; 13,500 gal; Sand filter; Pentair / Dynamo Filter Pump
    DFW, TX
    24,450
    Yep, once it goes it goes. As soon as you see a few dots in the pool get it outta there because the next step is LOTS of dots!
    Sep 2015
    Halfmoon/NY
    4
    Got home and SWMBO had removed the cover from the pool and tossed it out. She ordered a new one, $60 & free shipping!
    Jun 2012
    Michigan
    154
    Something I was recently told too, as I just had to replace mine after about 3 years of use, was that you're supposed to take the solar cover off your pool when you shock it, as the super high doses of chlorine just eat at it quicker. Although I also had mine on when I shocked and it did last 3 years, so that may have just been pool store sales guy trying to sell me stuff talk.
    Intex 16x48 UltraFrame AGP, included filter pump
