Thread: Suction Cleaner for Fiberglass Pool
    teat461's Avatar
    Jan 2016
    Newton,NC
    7
    My pool has the safety ledge around the perimeter near the bottom. Will a suction cleaner make it up and over the ledge? What kind to get? I was thinking of the Barracuda G3.
    Teat461
    14 x 31 fiberglass pool , 12,500 gal, SWG, Jandy Pro Truclear 3/4 hp pump, sand filter
    malcolmb5325's Avatar
    Sep 2009
    Sydney, Australia
    166
    Re: Suction Cleaner for Fiberglass Pool
    With a fiberglass pool the wall are very smooth so you don't necessarily need a cleaner to climb the walls as the dirt will slip off and down onto the floor so really you only require the cleaner to cleaner the floor. A suction cleaner like the Baracuda requires the skirt to maintain contact with the pool surface to help it move so once it hits the ledge the skirt will lose contact/suction and possible fall back to the floor or may hang on the ledge depending on how far it climbed up.
    16,000lts Fibreglass, Magna Mineral Pool Water
    Jandy CV340 Cartridge filter, Zodiac TRi SWC, Z4 iAqualink, Jandy Laminar Jets, Solar Heating, Spa Jets with Jandy 1.5hp Epump operating everything.
