Thread: Losing pressure?
    Losing pressure?
    Hi all!! I am experiencing problems with my pentair pump. The pool seems to operate normal when both skimmer and main drain are pulling water. The problem comes when I switch the diverter valve to skimmer only. The water level in the strainer basket immediately drops by 20% or so then the pool slowly loses pressure. Once the diverter valve is turned back to both skimmer and main drain the pool will recover and seems to run fine. The same thing happens if I turn the diverter to main drain only. The pool also loses prime if turned off for more than 30 mins to an hour. When the pool is running, there are no air bubbles in the strainer basket. We recently replaced the strainer lid and gasket and also replaced a gasket in the diverter valve. Any help would be greatly appreciated...
    Pentair challenger 1.5 hp
    18x36 IG vinyl liner, sand filter, approx 26500 gals, Aquabot pool cleaner
    Loving my pool, thanks to the BBB method :)
    Dec 2014
    Santa Ana, CA
    523
    Re: Losing pressure?
    Quote Originally Posted by HotNTexas View Post
    sounds like you meant 'pump' where you wrote 'pool'. Anyway, I'd recheck parts you replaced, as they might very well be responsible.
    44k plaster pool, Pentair 011018 pump, DE6020 filter, LED lights, K2006 test kit
    30,405
    The first thing to break is the last thing you fixed!
    What size are the pipes coming from the skimmer to the pump?
    I believe the pipe is 1.5 inches. I'll get my husband to double check.
    The pool has been having problems most of the summer. The lid and gaskets were replaced in an attempt to fix the problem. I'm not good with pool lingo so I may have called some parts by the wrong name. When I said the diverter gasket I was referring to the gasket on the valve that changes the suction from the skimmer to the main drain.
    Also, I noticed tonight the pump lost prime within 5-10 mins of being turned off.
