Thread: PH always high, tough to get down in SWG
    Jul 2016
    Middletown, DE
    1
    aving issues with continuously high PH, practically swimming in 1-2 gallons/week! Struggling to get below get below 7.8 and keep it maintained. Read a few threads from here and seem to have a better grasp at least but still want to check. Water clear as can be. Water temp 90 as of today. Fresh test results from this afternoon:
    FC- 3.26
    TC- 3.47
    CC- .21
    pH- 8.0
    Hardness- 135
    TA- 82
    CA- 52
    Borate- 35
    Salt- 3370
    Thoughts are to raise borate to 45ish with 10 lbs Endure, lower pH to 7.8 with gallon of MA, raise CA to 100ish
    Correct order? Proper amounts?
    Is there a "proper" amount of run time for SWG to eliminate the out-gassing I think they called it? Better to run 3-4 short times? or like now 2 times/day, 5 hours each (6am-11, 2-7)?
    Is there a way to run pump for filtration and not run SWG?
    In-ground, 35000 gallons, vinyl, SWG, DE Filter, 7 yrs old
    will fill out other info after I get a chance
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,184
    Re: PH always high, tough to get down in SWG
    You want to try to get the pH a little more under control if possible. My pool likes the TA in the 50-60 range before pH rise begins to slow down.
    Support the site
