Thread: Question about using Bromine
    Jul 2016
    Fayetteville
    5
    So I purchased a home about 2 months ago, and the spa was completely empty (apparently they shut it completely down during the summertime.)
    I did not know about this site yet, so I simply filled it up, then took my water into the local pool store...................
    They gave some stuff to put in, don't remember exactly what, and it seemed to balance out fairly well, according to the follow-up reading. Since then I have been adding a bromine tablet about every 2-3 days to the little basket, and was checking the bromine level every few days with this cheap kit that I had purchased. (I have a better kit on the way currently)
    Anyway, took a sample to the local pool store yesterday and got the following readings:
    Bromine- 2
    Ca Hardness 90
    Tot Alk 30
    pH 7.2
    tds 425
    My question is about the "bromine reserve". I'm not sure I ever completed this step. Also, I have never shocked it, or put anything else in it.
    The water seems to be clear and odorless.
    My question is, what should I be doing from this point forward?
    I've already ordered an adjustable floating tablet dispenser, since that seems to be the recommended way to go. I also realize I need to increase the CA Hardness and total alk. My main concern right now is with the sanitizer though. Thanks for any help!
    Pool: 17,925 Gallons, Hayward Pro Series Sand Filter Model S244T, Aqua Rite SWG
    Spa: Maui Brand, 450 Gallons
    Mod Squad pooldv's Avatar
    DFW, TX
    24,450
    Re: Question about using Bromine
    I don't know much about bromine. But, here is some good info.
    How do I use Bromine in my spa (or pool)?
