Thread: New Pool Trouble
    Jul 2016
    New Smyrna fl
    32
    New Pool Trouble
    Just started excavating for our pool and found buried debris. It is small palmetto root debris that may cause more complications excavating because of how deep (14 ft) and near our home foundation (5ft). I assume they already ordered pavers etc. One of the options was for us to sign over liability from their lifetime shell warranty dig 10 ft and fill with 3ft pea gravel, which is out of the question. We suggested to have our land cleared push pool further away from house and excavate all debris then back fill with new dirt. If they still don't agree to those terms without signing a waiver we do not want to build. If pool builder is not able to build pool without waiver do they return my deposit? Any other insight on this whole situation would be appreciated as well.
    Jan 2016
    Mesa, Az
    541
    Re: New Pool Trouble
    Ask if you do an engineered base, if they'll honor their shell warranty then. Something like this . . .
    3 foot overdig, geotextile fabric, 2 feet of 3" rock or crushed concrete (coarse aggregate), capped with 6" of "road base" (3/4" minus) compacted to 95% density, then six inches of pea gravel to set your plumbing lines for the drains in.
    Jul 2016
    New Smyrna fl
    32
    Quote Originally Posted by BigEinAZ View Post
    So overdig the pool 3 ft and use the materials you suggested. If some debris remains this should be able to support?
    Jan 2016
    Mesa, Az
    541
    Yes. A structural engineer would need to be consulted and he may suggest tightening up the rebar spacing a little, but the builder shouldn't have any realistic cause for concern if an S.E. stamps the plan. I've built two story concrete structures on spread footings on this type of system and have had zero settlement issues.
    Jul 2016
    New Smyrna fl
    32
    uuuu
    Jan 2016
    Mesa, Az
    541
    For a couple hundred dollars have licensed engineer review and approve your plan. There may be local conditions that you haven't revealed (or don't know about) that may alter the way the base is constructed. What I have suggested is a plan I have used often, in my area, with engineer's approval and with great success. Your situation may be different.
