Results 1 to 11 of 11
Thread: Intelliflo pump shot?
    Jun 2013
    Philadelphia, PA
    143
    I have an Intelliflo pump that is JUST over three years old (So out of warranty.) Noticed it wasn't running this evening. Go outside and the LCD is normal, but the Start/Stop LED isn't lit. Figured I must have left it off or something after cleaning the pool yesterday. Turn it on and it tries to start. RPMs come up, watts really don't. Then it goes to prime and RPMs go way up, watts barely come up. Almost no noise (Thing should be screaming right now.)
    Tried a few things, couldn't get it working. Flipped the breaker. Emptied out the water and can move the impeller freely. Filled it back up, breaker on, tried it again. Nothing.
    Took a video - sorry for the orientation. Anyone ever encounter this or had one apart? Really don't want to have to replace this and hoping I can get whatever parts are needed.
    Pentair Intelliflow - YouTube
    Leisure Pools Riv 30, 8500 gal, IG fiberglass, 200 sqft cart filter (Clean & Clear 200), Intelliflo 3HP variable speed pump, Aqua Rite SWG, auto cover, installed 5/2013
    Aquacal Superquiet 110, installed 6/2014
    TFT 100
    Oct 2014
    Sacramento, CA
    72
    Re: Intelliflo pump shot?
    I have had a few pumps do this and its just a bad board.. unfortunately buying a board you mid as well buy a new pump... i think the boards are about 600.00
    David Randolph
    Warranty Station
    Pentair
    Jandy
    Owner Sac Pool Pros
    mas985's Avatar
    Pleasanton, CA
    11,737
    Do you have surge protection on the pump power?
    Mark
    Jun 2013
    Philadelphia, PA
    143
    I have whole house surge protection on the main panel. Guess it's needed on the pool subpanel too? SWG is still powering, no way to tell if it's actually working now. . .
    TFT 100
    mas985's Avatar
    Pleasanton, CA
    11,737
    It depends on how it was wired but usually you want local protection at the pool panel itself.
    Mark
    Jun 2013
    Philadelphia, PA
    143
    Do you guys recommend the same whole-house surges that would be used on the main panel at the pool sub panel?
    TFT 100
    mas985's Avatar
    Pleasanton, CA
    11,737
    Definitely! Too many times we see VS failures due to lack of surge protection.
    Mark
    Jul 2015
    Dayton/Maryland
    83
    Could you recommend a good surge protection for intelliflo?
    Quote Originally Posted by mas985 View Post
    2003 Build 20K gallon salt water gunite IG pool, Taylor 2006 test kit, Pentair 011018 IntelliFlo Variable Speed Pump, Pentair IntelliChlor IC40 SWG, Aquabot ABTTJET Turbo T Jet Robot
    Jun 2013
    Philadelphia, PA
    143
    I have a whole house surge (Leviton or one of the popular ones.) I'm considering a lightning arrestor from Delta (Delta Lightning Arrestors) and possibly the surge at my sub panel.
    I need to also open up my sub panel and make sure things are grounded correctly and separate from the neutrals, etc. Everything passed inspection when installed, and I'd like to think the installer and inspector did things right. Seems the grounding vs bonding makes the best electricians question how things should be from time to time. Too often these topics seem to get confused for each other.
    TFT 100
    Jul 2009
    Gonzales, La
    220
    Can someone please post a picture or direct us to a thread that has the surge protectors. I took a close lightning strike and suspect my pump board is fried as well. I'd line to install a surge protector to protect the panel and pump if possible
    Todd
    15x36 Gunite w/Diamond Brite(Bahama Breeze plaster), 3.5-6', Pentair Easytouch Automation panel, Pentair 3HP VS pump, Pentair CNC 420 filter, Pentair 5G color changing light, Polaris 360 cleaner w/booster, Pentair IC-20 SWG
    My pool build
    http://www.troublefreepool.com/threa...ales-Louisiana
    mas985's Avatar
    Pleasanton, CA
    11,737
    Here is a good article on comparing surge protectors: What Whole-House Surge Protection?
    And here are a bunch of threads on it: Surge Protection
    Mark
