Thread: TA ?'s
    Jul 2014
    kamloops bc
    39
    TA ?'s
    All my readings are fine by TFP standards except TA at 160 seems high. I have read on here that one should not target a # for TA, but am concerned that it is high and wondering if I should attempt to lower it?? My CYA is still under 20 but am working on bringing it up to 30
    FC 3
    CC .5
    TA 160
    PH 7.2
    CH 175
    14 x 28 IG, Hayward sand filter, Hayward 3/4hp pump, auto puck chlorinater,(used only when away) Hayward Natural gas heater, vinyl liner
    Catanzaro's Avatar
    Jul 2014
    Monmouth County, New Jersey
    2,264
    Re: TA ?'s
    What about PH? Your TA is what keeps your PH in check. I would check the PH a few times daily to determine if there are large swings. If so, then the TA may need to be lowered. We will need more information. Additionally, what test kit are you using to provide your readings?
    14,700 gallons IG Pool Vinyl Liner - Octal Circulation System
    Hayward Pro-Series 350 LB. Sand Filter Model # S270T - 2" Plumping
    Hayward CL2002 Chlorinator - Hayward Super Pump 2 HP Model # k48m2n111
    Hayward AQR9 SWG 25K Salt Cell & TF-100 Test Kit + Speed Stir
    Gulfstream HE125RA - 117K BTU Heat Pump - Date of Build is 11-2013
    Jul 2014
    kamloops bc
    39
    Re: TA ?'s
    PH has been pretty stable at 7.2, a week or so ago it looked a tad bit low so threw in some Ph up and it went to 7.4 for a few days then back to 7.2
    Test kit is 2006
