Thread: Two different sets of instructions from TF-100 kits for CH
    Jul 2011
    Las Vegas, NV
    57
    So I bought a new TF-100 to go along with my new pool and because my old one got misplaced, but since found the old one but got the instruction cards mixed up and I can't tell which is the old one. One says to add 20 drops of R-0010, 5 of R-0011L and multiply by 10 while the other says to add 10 of R-0010 and 3 of R-0011L and multiply by 25. Which one should I be using or are they the same end result?
    Feb 2016
    Baytown, Texas
    40
    Re: Two different sets of instructions from TF-100 kits for CH
    If you are going to add 20 drops of R-0010, then you are going to be using 25ml of sample water. if you use 10 drops your are using 10ml of sample water. I am using the Taylor K-2006c kit and it has the instruction for both. Good luck
    Xavier in Baytown, Texas
    Pool Built: 06May2016. 16ftx34ft, Area: 485 ft2, Depth: 4ft-6ft, Pentair IntelliFlo Variable Speed Pump, Pentair FNS Plus D.E. Filter 48 sq. ft., Easy Touch 8 with wireless remote, IntelliBrite Pool Color LED, 640 Sq Ft of deck, 3 ton waterfall, Guesstimation: 17,000 gallons, Test Kit: Taylor K-2006C.
    Jun 2014
    15,243
    Administrator Leebo's Avatar
    Jul 2011
    Eastern Ohio
    7,109
    This change was made a few years ago to help the user save reagents. By using only 10ml of water and ten drops you are losing a slight bit of accuracy but saving a ton of reagents. Both will work just fine.
    Jul 2011
    Las Vegas, NV
    57
    Great thanks all, I'll toss the extra older sheet then. I thought I was going crazy because I had them both in the box for some reason so sometimes I would use the old card and wondering why I was using so much reagent when I didn't have to the previous week lol
    10,000 IG Plaster w/Spa | Hayward Colorlogic LED lights| Hayward C3030 Cartridge Filter | Hayward H400FDN 400k BTU Heater | Hayward SP3220EE TriStar 2 HP single speed pump | In-floor cleaning system | TF-100 | Build finished Jan 2016
