Thread: New water startup
    Jun 2013
    Cypress tx
    9
    New water startup
    Looked by didn't find anything on new water startup.
    Drained and refilled for the first time. Spa about 6 months old.
    Have a start up chem kit but i wasn't present when they filled.
    Any basic chemical add to start with?
    We are on well water.
    450gl spa.
    Michael
    20000 gal
    in-ground plaster, replaced early 2015
    Cartridge filtration,
    single speed pump
    well water
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: New water startup
    Are you going with a bromine or chlorine spa?
    Check out the two sticky threads:
    How do I use Bromine in my spa (or pool)?)
    How do I use Chlorine in my Spa (or pool)?)
    Also... if you've never done so, consider a deep cleaning of the spa plumbing using a spa flush product. Ahh-some jetted spa and hot tub cleaner is the best I've ever used.
    Isolated Spa - 345 Gallons
    Nov 2015
    appleton wisconsin
    152
    I don't do anything special.
    1. start up with dichlor chlorine granules. put 3ppm fc to start, then 10 more after a good long soak.
    2. keep a good watch on ph. running the air jets makes it go up at first for me, so I wait for the water to breathe for a while before i correct. Also, keep in mind, dichlor is an acid that you'll be adding for a while.
    that's it
    340 gallon stand alone spa.
