Thread: Above Ground Pool Fence and Pool Cover
    Jul 2016
    Canada
    1
    I'm hoping someone out there, anywhere, will have a good idea for me.
    I have a 21' above ground. Want to install a decorative/safety fence to the pool. Here is where my challenge is....how do I get my pool liner in and out of the pool ?! Ideally I would love to use a solar cover roller...that seems even less possible. No idea how to do either of these things. Desperately seeking advice / creative ideas.
    cj3737's Avatar
    Jun 2016
    North Ogden, UT
    629
    Re: Above Ground Pool Fence and Pool Cover
    I too have pondered this idea...
    The only thing to make any of that process easier, is to get in the pool when you are covering it back up... Takes the fence out of play, then you can lock it up as necessary.
    Ive looked around a lot and that is the easiest thing to do with a roller installed.. Just extend the fence wide enuf to access the roller on both sides
    Inherited 24' Muskin Above ground
    13500 gal
    Hayward S180T92S Sand filter
    Taylor K-2006C Speedstir
    TFPC for Beginners | Pool Math | Pool School | CYA Chart | SLAM | Test Kits | ABC's
    Quote Originally Posted by Shona View Post
    I have zero familiarity with above-ground pools but is there not a general requirement for safety fences like we have for in-ground pools? I can't even get insurance unless I have a conforming fence.
    Geebot
    Chicago, IL
    30K gal, InGround Plaster Finish, 3.5'-9.5', Maytronics S300 Cleaner
    RyanMcC's Avatar
    Aug 2013
    NH
    214
    Yes, but the "above ground" part is usually high enough to count as a fence. Stairs/ladder that are removable or have a locking gate finish off the requirement.
    "...chemistry is not an exact science" -Mario Andrada, Rio 2016 Olympics spokesman
    21' x 52" Radiant Metric Round ~10K gal AGP with Hayward S180t pump/sand filter.
    Caldera (Watkins) Martinique 340 gallon installed in basement, Bromine and ozone.
    Taylor K-2006 test kit.
