Thread: Zeosand ??? Cleaner
    rolo918's Avatar
    May 2015
    Macomb mi
    95
    Zeosand ??? Cleaner
    Do I need to run a cleaner through my zeosand filter ???? No matter how good my water chemistry is and it is good . my water looks dull ??? The sand is about two years old ???
    Chris- Macomb, Michigan 20,000 gallon pool IGP. 16 x 32 Hayward Ecostar pump. Hayward 24 inch sand filter with Zeo sand. Hayward Aqua plus P4 automation board with T-15 turbo cell. Hayward H150 heater millivolts style. Polaris 9300 robot vacuum. New maytronics titain plus vacuum cleaner Test kits TF-100 and color Q7 TEST KIT.http://tftestkits.net.
    Mr Bruce's Avatar
    Mar 2014
    Greenville, SC
    2,071
    Re: Zeosand ??? Cleaner
    Post a full set of test results. Sand is probably fine, although a one a year deep clean is a good idea. Deep Cleaning a Sand Filter
    32K gallon Plaster - CircuPool SJ-55 SWG - 1hp Hayward 2 speed Super Pump - Hayward S200 Sand Filter - TF100XL/K-1766
    Test Kits - Pool Math - Chlorine/CYA/Target/Slam Chart - Support TFP
    rolo918's Avatar
    May 2015
    Macomb mi
    95
    Zeosand ??? Cleaner
    I'm in the middle of a SLAM I started it yesterday so I will give you my readings what I had yesterday.
    rolo918's Avatar
    May 2015
    Macomb mi
    95
    here are my numbers
    ph7.5
    fc10
    cc.5
    tc 10.5
    TA-90
    CYA-80
    no need for CH I have a vinyl pool
    the reason that the FCis 10 cuz I had a pool party on Sat. and bump it up to 12 before the party
    everytime we have 10 or more people in the pool after an hour or 2 it gets hazy
    Apr 2015
    tucson, arizona
    1,120
