Thread: Air Bleed Tube Assembly
    Jun 2016
    Lafayette, LA
    5
    I noticed the top of my air tube bleed assembly was cracked, so I ordered a new one online and the new one came with a screen mesh instead of the plastic top. I'm checking with Pentair to see if this is the correct replacement or did I receive the wrong part, should be part number 178583 (CCP520 installed after 11/98). I installed the one I received, but the mesh filter does not reach the bottom of the bleed valve or the top of the filter, whichever way you want to describe it. I've also noticed that I have to bleed the air in the filter every morning after the pump has run its cycle to get the filter to fill back up.
    does not having the correct or cracked bleed tube assembly allow the water to drain out of the filter when the pump is turned off? I bought this house with pool a couple months ago and don't recall having to bleed the air as often. I would check it periodically and maybe there was a small puff of air that would escape. I did buy a new o-ring but have not installed it yet. The unit is 8-10years old so I'm wondering if the o-ring could be the issue or maybe I'm not putting the clamp back on correctly.
    Mike
    Freeform 24' x 38' IG gunite. 3 1/2' to 8' deep. 28,500 gallons. AutoPilot Total Control SWCG. Pentair Intelliflo VF. Pentair CCP520 cartridge filter. Colorlogic LED lights. Tahoe Blue Diamond Brite. 1200 sq ft stamped concrete deck.
    Apr 2015
    tucson, arizona
    1,124
    Re: Air Bleed Tube Assembly
    That is the correct part no. Although they may have changed the design since '98. Very important to remove o ring clean around tank and replace. If the o-ring is flattened at all replace with new one. As you tighten nut on clamp take a mallet or such and tap around clamp. After you run for awhile check for leaks and then turn off and listen for any siphoning or draining of tank while off.
    Jun 2016
    Lafayette, LA
    5
    Replaced the o-ring this weekend. The new one fits snug against the filter, I didn't realize how stretched out the old one was and the clamp was much easier to re-attach. Now there is no siphoning when the pump shuts off. Contacted Pentair and that is the correct part so i'm waiting on a new one to arrive.
    Now that I have that problem resolved, next one up is getting rid of what looks like rust stains around the bottom, but that's for another thread. I don't recall the stains being that predominant when we moved in but I may be more aware of things now.
    Mike
    30,426
    Better served to keep that question right in this thread. Responders like to see the "whole" story even if the issues are unrelated.
