Thread: Brown algae and red worms
    The top of the water is clear but can't see the bottom, I have been sweeping brown algae from the bottom, and now I have seen some little red worms. I put 1 bag of shock in 2 days ago and a big chlorine puck that is floating around I just added some more chlorine granules in around the pool.
    the FC was .5 and PH about 7.2
    Matthew
    Involved in the pool and spa industry
    Pittsburgh, PA
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: Slightly green water
    Quote Originally Posted by cbrewer
    Welcome to the forum, please post a full set of results, and also if you could put your pool info and specs in your signature, that would be helpful and we can advise you better.
    Go to User Control Panel, then Profile, then Edit Signature.
    Also how are you testing your water?
    Have you read Pool School?
    Jun 2007
    NC
    255
    Re: Brown algae and red worms
    First: WELCOME!
    Second: If the water is clear you can see the bottom. It sounds like it's cloudy, probably due to the algae that you've been sweeping around but it may be due to algae floating in the water too.
    Third, This URL has the information that you'll need to know <http://www.troublefreepool.com/what-...ns-t10341.html >. Lots of great people hang out here and are more than willing to help out but they need information...
    By the way, a FC level of 0.5 is low, no matter what CYA (stabilizer) level you are at. 8)
    Triad Region of NC
    18x37 Vinyl IG (24,000 gal.), BBB & GoldLine AquaLogic PS4 SWG, Hayward 1 HP Superpump / Hayward Sand Filter / Polaris 280 cleaner / 6 deck jets / Sheer Descent Waterfall (in coping) / Brick Red Concrete Coping / Stamped Concrete Deck
    Lots of oak trees, maple trees, *and* leaves!
