Results 1 to 7 of 7
Thread: CYA /Chlorine ratio and fading of swim wear
    Oct 2014
    Beaumont, CA
    47
    Question CYA /Chlorine ratio and fading of swim wear
    We know CYA attaches itself to chlorine and protects from sunlight, but what about our swim wear fading? Is higher CYA along with chlorine any different on clothing than lower CYA and chlorine? Trying to find the happy medium here if there is.
    16x48 Summer Escapes Pro-Series Above Ground frame pool, 5000 gal, Intex sand filter - Looking for heating solutions for AGPs
    Piolin's Avatar
    Sep 2010
    Miami, FL
    604
    Re: CYA /Chlorine ratio and fading of swim wear
    I keep my CYA at 70 and keep my FC at 7 in sunny Miami, Florida and I don't notice any fading in our swimming gear
    Starting day 5/25/2015 INTEX AGP 24'x12'x54" 8,400 gal, with salt and borax, INTEX 3,000 GPH pump with 16"sand filter, WM Hayward Skimmer, Intex SWG CG-28669, 1 1/2" hard plumbed PVC, Lil' Shark Vacuum With Leaf Canister, TF100 test kit, speed stir, K-1766 Taylor salt test
    http://www.troublefreepool.com/conte...art-slam-shock
    8,400 gal Intex, 3K GPH pump, 16" sand filter, SWG CG-28669, TF100 test kit, speed stir, K-1766 Taylor salt test.
    The corner stone of TFP
    Pool School - Chlorine / CYA Chart
    Jan 2014
    Buckeye AZ
    807
    Chlorine attached to CYA is effectively ineffective. Proper cya/FC ratio will protect you, your suit, and your equipment.
    10,500 gal IG, Topaz Pebble, auto-level
    Hayward DE filter, 2HP Ecostar VSP, ProLogic PS-4, GVA actuators
    Cal Pools Wave Force Plus (wall return jets plus 2 floor pop-ups), Venturi Skimmer
    Water sheer, 2 wok pots, bubbler stem on the baja step
    ColorLogic Mutlicolor LED lamp. Taylor 2006+speed stir
    30,432
    CYA protects swimwear very well.
    A pool with 5 FC and 60 CYA protects swimwear better than a pool with 2 FC and 0 CYA
    Donldson's Avatar
    NW Ohio
    2,920
    Better than a pool with 0 CYA and 0.5 FC. The ratio used by TFP is very easy on skin, eyes, and clothing (as well as pool equipment), so much so that many people who believe they have negative reactions to chlorine based on other pools almost always show no reaction to a TFP pool.
    JD - 28' Round Above Ground Pool, 17,000 Gallons. Dual speed Jacuzzi pump with cartridge filter. Dual speed 1 HP pump, Hayward S210T sand filter
    Pool School - PoolMath - HIGHLY Recommended Test Kits
    Oct 2014
    Beaumont, CA
    47
    Great! I think ill stay right where im at
    CYA 50
    FC 6
    UN1017's Avatar
    May 2012
    Sacramento, CA
    288
    Many think it's the pool water that fades their swimwear...but it is usually the leaving of swimwear outside in the sun to dry that does the most damage. UV rays are ruthless.
    15'x30' IG - Roman-style - 14K - Pebble Fina Classico
    Filter: Jandy CL460 Pump: Jandy Stealth SHPF1.5 SWG: Jandy AquaPure 1400 Cleaner: Jandy RayVac Test Kit: TF-100 w/SpeedStir
    Chlorine/CYA Chart----Extended Test Kit Directions----SLAM
