Results 1 to 13 of 13
Thread: new test kit user; need assisit
    Apr 2016
    Poway, CA
    10
    Thanks for all the people who keep this site going!
    I have a gunite pool that over the winter developed some hard stuff
    on the sides. I just had it drained and polished and am starting up.
    The quartzscape finish is one year old already.
    My difficulty is that it is an outdoor pool with a cover on it. Some of the
    pool math is based on recommend FC levels depending on the CYA level.
    What level should I use? From research I'm leaning toward 20 ppm.
    Here are my startup levels:
    TC 1.5
    FC 2.5
    CC .5
    Ph 6.6 (should I add borax)
    TA 2400
    CH 200
    CYA 0
    I turned the SWG on with the filter but need to know when to add (how much) salt.
    Thank you!
    Inground; 4875 gal; automatic cover; Coates Model TR Heater;Pentair Intelliflo pump; Intellichor salt gen; Poolmiser auto fill; DE filter; gunnite
    30,408
    Re: new test kit user; need assisit
    How often is the cover on it?
    You have some incorrect test numbers, I think. How are you testing?
    Apr 2016
    Poway, CA
    10
    The cover is on it 20-23 hours a day. I'm using the TF-100; which value should i repeat?
    Jun 2015
    Raleigh
    357
    Quote Originally Posted by Poway View Post
    TC = FC + CC, so your TC cannot be less than FC
    Your alkalinity (TA) at 2400 is suspect...most pools are 150 or less
    Don't turn the SWG on until you add 3000 to 3500 ppm of salt
    With a SWG, you'll want to shoot for 60 to 70 CYA
    18' x 38' Pool, 3' to 8' Depth
    Vinyl Liner
    SWG
    Variable Speed Pump
    Sand Filter
    Mr Bruce's Avatar
    Mar 2014
    Greenville, SC
    2,071
    That pH is crazy low, that should be brought up pretty quickly. CYA for a SWG should be 70-90. That TA is probably not right, but don't worry about that until you get your CYA and FC up.
    32K gallon Plaster - CircuPool SJ-55 SWG - 1hp Hayward 2 speed Super Pump - Hayward S200 Sand Filter - TF100XL/K-1766
    Test Kits - Pool Math - Chlorine/CYA/Target/Slam Chart - Support TFP
    30,408
    TA can't be 2400. multiply the drops times 10. Could it have been 240?
    I think the TF-100 only goes to 6.8 pH Does it go as low as 6.6? (I can't remember)
    If you tested FC @ 2.5 ppm and then tested CC's @ .5 ppm then your TC needs to be 3.0 - let us know which is right.
    We'll help you get your pool straight but let's get your numbers right to get started
    Apr 2016
    Poway, CA
    10
    Sorry guys I was using the test instructions off the site; but pulled the wrong kit instructions so my multiplier for Akilinity was off.
    TA is 120
    I tested FC and CC so adding those gives 3.0; but what is the value I put down was from the Daily test of K-1000; my mistake
    TC is 3.0
    I'm reading the PH also from the daily test of K-1000 also should I not record that either? Where else am I testing Ph?
    Mr Bruce's Avatar
    Mar 2014
    Greenville, SC
    2,071
    That is the only pH test. If you really think it's 6.6, just shoot for 7.0 for now, then retest.
    CYA is next, without any your FC will be used up in a day.
    Apr 2016
    Poway, CA
    10
    What will eat up the FC if the cover is in place?
    Mr Bruce's Avatar
    Mar 2014
    Greenville, SC
    2,071
    Well, I guess if you had a cover that completely shut out 100% sunlight, and had perfect water, nothing. But seeing how algae can grow even in ladders and behind pool lights, it doesn't take much sunlight to lose FC or let algae grow. Also, there is bather load; if you have a completely blacked out pool that never saw a swimmer I'm not sure what the point would be
    Side note, you need some CYA even if the pool is indoors, it is an important buffer.
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Not much other than dust, debris already present in the pool if the cover is 100% UV blocking. Do you plan on having the cover on and never swimming in it? Even indoor pools should have 20 ppm CYA simply to moderate the strength of the hypochlorite and allowing more leeway with FC levels.
    Isolated Spa - 345 Gallons
    Apr 2016
    Poway, CA
    10
    Nah...we will use it for swimming. I'm just doing startup is why there is no CYA. I wanted an expert opinion on what level to
    shoot for.
    Feb 2014
    Central Minnesota
    5,080
    I'd shoot for 40-50 ppm CYA to start with, assuming you will be covering it nearly all the time. If you're not happy with that, you can inch it up to more recommended levels for SWG pools. It's easy to work the CYA up higher, not so easy to work it down (drain/refill).
