Thread: Convert Taylor "R" numbers to "HTH" or "Pool Shop" brand numbers.
    Jul 2016
    slidell
    58
    I have from previous kits 5 or 6 HTH reagents (alkalinity titrant, alkalinity indicator, hardness titrant, hardness indicator, phenol red, and OTO bottles, and also Pool Shop reagents # 1 - 5. Does anyone know which of these would correspond to the Taylor "R" series so I can perform tests w/o buying the "R" series reagents? thanks
    Blue haven kidney style 16,000 gal gunnite including Spa, test Kit TF - 100
    Built 2000 deep end 7.5 feet, 2 steps at shallow end
    Original SWG then convert to chlorine
    Pentair Clean & Clear cartridge filter (4)
    Blue Haven Teledyne Laars Platinum II heater
    Jun 2013
    Augusta, GA
    90
    Re: Convert Taylor "R" numbers to "HTH" or "Pool Shop" brand numbers.
    I cannot answer your question directly, but if you go to the tftestkits site, you can figure out your answer by comparing the tests your chemicals are designed for with the Taylor chemicals listed. Be careful, though, as the HTH chemicals may not be the same as the corresponding Taylor chemicals. I know that the Taylor phenol red also contains a CL neutralizer that other brands don't add to their dye. Others may be able to answer a little better than I.
    30'x52'' AGP 21,000 Gallons
    TWM 2.64 SF Sand Filter w/ Century 1.5 HP Pump
    BBB'er for life!
    TF-100 Test Kit
