Thread: What good is an inline chlorinator if it will drive CYA too high?
    Jul 2016
    Sacramento
    1
    I had a 19,000 gallon inground pool put in last summer. The equipment setup has a Zodiac Nature2 Fusion inline chlorinating system that takes 3" tabs. It also has the mineral cartridge.
    I've had zero problems with it until about a week ago, when the chlorine reading was at 1 or so (just a faint hint of yellow in the test kit) even though I had 6 tabs in it. I brought a water sample in to two different pool stores, and they both said the CYA was at 200.
    I've combed through a lot of the information on TFP since then, and it's no surprise that the CYA is high because all I've done for a year to chlorinate is run trichlor tabs.
    Which brings me to the question, what use is the inline chlorinator if it will eventually drive up the CYA levels to where they become a problem?
    As an aside, I haven't replaced the cartridge yet, and am getting the feeling that it might not be needed. Thoughts?
    Thanks.
    May 2015
    Land O Lakes, FL
    527
    Re: What good is an inline chlorinator if it will drive CYA too high?
    You could use it when you are vacation.
    It makes more $ for the tab manufacturers and the pool stores selling fix it potions.
    Matt
    2016 Pool Build: 12k IG Blue Granite Pebblesheen, Travertine Coping & Pavers, Pentair IntelliFlo, Intellichlor, Easytouch, Clean & Clear 320, Heliocol Solar - TF-100 test kit w/ SpeedStir
    SWG Run Time Calculator
    domct203's Avatar
    Jun 2015
    CT
    3,577
    As mentioned it could be used sparingly, same can be said for a puck floater.
    I would also stop using the Nature 2, it is adding metals to your water. With proper sanitation (eg chlorine levels), it is not needed.
    Dom
    Here is the Nature2 SDS. It is adding copper & silver. Excess copper will stain pool surfaces & turn blond hair green.
    http://appatek.com/MSDS/Zodiac/CF.pdf
    Dom - TFP Guide
    Intex 18' X 48" Ultra Frame AGP 6700 gallons | Two Intex CS8110 SWG's | Hayward Pro Series 21" Sandfilter | Hayward 1.5HP Power Flo Matrix pump | Hayward Thru-wall Skimmer | Wanda the Whale | 72 sq ft of Sungrabber Solar Panels with Hayward GLC-2P-A | Taylor K2006 Test Kit, Sample Sizer & Speed Stir | Click Here To Become a TFP Supporter!
