Results 1 to 19 of 19
Thread: First $500 electric bill
    mepcards's Avatar
    Sep 2015
    mesquite,tx
    253
    Was running the pump 24hrs a day, but im back on the timer..Electric bill went from $385 to $509 within a month here in Dallas...I freaked out!!!!!!!!!!!!! I do have a two speed motor, but not sure if the slower speed is efficient enough....so ive backed off to running pool 12hrs a day...Hope it comes down a bit....IF NOT, then I at least have two more high bills to anticipate before September always seems to drastically decline..I believe the electric company just charges what they want..lol
    24x16 doughboy Summerville..22" Waterway "sand" 1.5 HP 2sp motor..Misty Falls liner, and wedding cake stairs..
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,379
    Re: First $500 electric bill
    Look on the bill and see what the per kilowatt charge is. Most electric companies bump up 2-3 cents per kilowatt hour in the summer. $124.00 jump could be a combination of increased usage and increased rates. If you are not locked into a contract agreement with your electric company you may want to look for a lower rate.
    Love TFP? Become a
    TFP Supporter!
    mepcards's Avatar
    Sep 2015
    mesquite,tx
    253
    yea its like 13.5 cents per kw...Funny thing is we havnt done anything diff from the $385 bill....Pool was running 24hrs since april when I was dealing with algae problem..I decided to just leave it run 24hrs, and could live with a $385-$400 for a few months before pool season ends, but now im scared it will jump up even more now we finally hit 100..yes I need to shop around or get locked into a rate..
    Mod Squad pooldv's Avatar
    DFW, TX
    24,483
    Yes, a 2 speed pump on low is significantly more efficient. It will move half the water and use one quarter of the electricity on low. You should run the pump on low for filtering. It makes the filter more efficient too.
    mepcards's Avatar
    Sep 2015
    mesquite,tx
    253
    Then leave the pump on for 24hrs then on low? or still 12hrs at least? Because mine has the button on bottom of motor to change from high to low..
    Mar 2015
    South Texas
    411
    I was gonna say, why are you running your pump so much?!?! You only need to run it long enough to skim the surface of debris and to filter a little. I run my pump on low about 6 hours a day, split into 3 different run times evenly spaced out. And I have an SWG to chlorinate! Before I had that, I only ran my pump 3 or 4 hours a day total. Of course I don't have any trees around putting stuff in my pool either, but still
    15,000 gallon free form Viking fiberglass pool. Hayward Star-Clear Plus C12002 cartridge filter. Hayward Swim Pure Plus T-15 SWG. Testing with TF-100 Kit. 2 speed 1.5HP Supreme pump. Dolphin Nautilus robotic cleaner
    mas985's Avatar
    Pleasanton, CA
    11,737
    4 hrs on low may be enough. There really is no lower limit as long as you get enough chlorine in the pool. Running the pump longer to prevent algae is a myth. It is the chemistry that prevents algae not run time.
    You might want to read this: Pool School - Determine Pump Run Time
    Mark
    30,414
    Just a thought....... How much A/C did you use comparing the $385 billing period to the $509
    DFW, TX
    24,483
    True, it was pretty dang hot around here!
    On low for 4 to 8 hours should be plenty.
    mepcards's Avatar
    Sep 2015
    mesquite,tx
    253
    I usually try and keep the a/c temp around 75, but recently been reducing to around 73 since we have started to reach 100...I compared by bills from last year at this time, and the highest bill was in the high 300's, so im assuming its the 24hr running of the pump, for last year I was only running about 6hrs a day...I know all pools and pumps are different, but I hate when I talk to other ppl who leave them on 24/7, and they say it raised their bill like 40-50 bucks...Im like how????????????????? And if you see the temp I try and keep the house, that's pretty good considering where we live...
    30,414
    It's pretty easy to figure out how much that pump costs to run. Simply take the low wattage (for low speed) and multiply it by the cost per kw on your electric bill. (or high wattage for high speed)
    On low, I think you will find it quite reasonable.
    mepcards's Avatar
    Sep 2015
    mesquite,tx
    253
    Thanks...Im going to do that for sure when I get home....Thanks again like always for all the gooood info...
    Jun 2016
    Jamestown, SC
    67
    I feel your pain! Our first electric bill post pool was $421, significantly higher than its ever been. We had our pump running 24x7 for a few weeks and it was Hot, and our AC broke. Plus the well pump running almost 20 hours didn't help. It's easy to blame the filter, but it's probably not the culprit, lol. Spending time in the pool let's me keep the ac a few degrees higher. 94 degree pool water feels so much better than 94 degree air!
    1st time pool owner: 16x48 Intex Ultraframe, 5061 gallons, intex SWG, 1500 gph cartridge filter (635T) , Gorilla pad, SP1091LX Hayward skimmer, K2006 and K1766 test kits, high iron well water, Poolmate Metal out, 5 gallon bucket/polyfill filter
    Feb 2009
    Hampstead, NC, transitioning to Perfection, NC
    353
    Are you on a Time Of Day (TOD) rate? Or is the utility charging a demand KW rate as well as kwh? If either of these are in effect, timing of your usage is critical.
    16X32 AB, Pentair SD filter, 3/4hp Pentair Optiflo, CircuPool RJ30+ swg, TF 100, 19 X 37 igv, Pentair filter, 1hp Pentair Superflo pump.
    mepcards's Avatar
    Sep 2015
    mesquite,tx
    253
    I have no set rate, or contract with current electric company..We have so many, I really need to see about changing, or locking in a rate...I set my pump on lower setting, but the only downfall is that my fountain that is attached to my return jet is of course now weaker, and I rely on that to help keep the water cooler..We usually don't swim really until Saturday and sundays, so I can program to kick it up Friday night to start the cooling process..
    Oct 2015
    Katy/Texas
    411
    In the Houston area there is a price shopping site that Centerpoint has called Truecost. It looks at your previous usage and the different rates available. It's a free service. I paid $0.081/KWhr this past billing cycle.
    In ground, 14,000 gallon, white plaster, unheated, stone waterfall, DE Filter, Rainbow 320 Cl, Polaris 3900, FloVis flow meter, F100 test kit, Circupool RJ30+ SWG, Circupool VJ1/Speck Badu EcoM3V variable speed pump.
    mepcards's Avatar
    Sep 2015
    mesquite,tx
    253
    Yes ill go look for sure....I think im .13cents across the board
    Jul 2009
    Houston, Texas
    9,379
    Your power company probably has a feature on their website where you can look at your historical usage from last year. You can check and see if your rate went up. Also if you have not had the a/c serviced in a few years you may want to look into having that done. Cleaning the evaporator coil annually helps the unit to run more efficiently.
    Love TFP? Become a
    TFP Supporter!
    Aug 2014
    Houston tx
    2,524
    Also, 73 and 75 degrees for ac is pretty chilly, at least for me.
    Marla
    No longer living vicariously through other people's pool builds. Pool build is complete on my IG SWCG pool, approx 10,000 gallons. All Jandy equipment - VS 1.5 hp pump, 580 cartridge filter, AquaPure 1400 salt cell, AquaLink PDA system. Dolphin m500. PebbleSheen Blue Surf with shells and beads added. TF-100 w/ SpeedStir. A Houston Pool Build Inside the Loop
