Thread: A little sand in my pool
    Jun 2016
    Suitland, MD
    18
    I got done with my SLAM and the water is looking better than it has in years! Over the last couple of days I have noticed a little sand coming up in my pool cleaner bags. It's not a lot of sand but I don't want it to turn into a problem. What should I be checking?
    Sue from Maryland
    13, 000 gal. 24 foot round pool, vinyl, in-ground (no main drain), Hayward sand filter, 3/4 hp pump, Aquabot s2-50
    Mr Bruce's Avatar
    Mar 2014
    Greenville, SC
    2,087
    Re: A little sand in my pool
    If sand is collecting below the returns, that is a sign that there is a pump problem (laterals, etc). If it's evenly distributed and you only notice it in the cleaner, I wouldn't worry about it too much. I also get some sand in my cleaner and chalk it up to the things that fall in the pool and tiny pieces of my ancient concrete deck.
    32K gallon Plaster - CircuPool SJ-55 SWG - 1hp Hayward 2 speed Super Pump - Hayward S200 Sand Filter - TF100XL/K-1766
    Test Kits - Pool Math - Chlorine/CYA/Target/Slam Chart - Support TFP
