Thread: Leaving SWG for Liquid Chlorine
    Apr 2014
    Northern Virginia
    11
    My salt cell is dead and I'm planning on using liquid chlorine for the remainder of the season. I had a few questions.
    1. The SWG's power is configured to work off the main pump on the same circuit. I've set chlorine production to zero but I'm wondering if there's some way to disable the power to the unit, and whether this is even necessary -- I am merely interested in reducing energy consumption.
    2. Should I do anything about my salt levels, which were maintained at the correct level when I was running the SWG?
    3. Any other cautions on making this transition? Given the cost, I may decide to run the pool on liquid chlorine and never use the SWG again...
    Thanks.
    34K, IG, Charcoal Marquis aggregate finish, Jandy stealth pump, cartridge filter, Built '07, TFT-100, Aquapure SWG, Solar heating with Goldline controller, Polaris 380 Blackmax
    Mar 2015
    South Texas
    411
    Re: Leaving SWG for Liquid Chlorine
    Quote Originally Posted by kr8434 View Post
    Thanks.
    1. I would simply unplug the power cable to the unit myself
    2. Many people put salt in their manually chlorinated pools. Won't hurt a thing
    3. Biggest thing here is to check your CYA level and make sure you're adding enough chlorine to stay above recommended levels in the FC/CYA relationship. Chlorine levels are a bit higher for manually chlorinated pools. If your CYA levels are high, you might want to do a partial drain.
    15,000 gallon free form Viking fiberglass pool. Hayward Star-Clear Plus C12002 cartridge filter. Hayward Swim Pure Plus T-15 SWG. Testing with TF-100 Kit. 2 speed 1.5HP Supreme pump. Dolphin Nautilus robotic cleaner
    Jun 2014
    Roseville, CA
    343
    The salt will eventually dilute away.
    Regarding power, there is no real reason to disconnect it. The power light may be on using a few watts. I suppose you could disconnect the wires at the source (not the SWG) taking it off line completely.
    SWG: CircuPool (5/2018) Universal 40; 3000ppm seems ideal;
    My Ideal Specs:
    FC 5; PH 7.4-7.6; TA 90; CH 350; CYA 75; = SI ~ 0.19
    14,000 gal, in ground, plaster, Cartridge filter, Borates
    TAYLOR K - 2006 Last Circupool SI30+ 4 years RIP.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,485
    I would leave the salt in the pool. You would likely miss it and notice it was gone. Salt improves water feel for skin and eyes because we are salty.
