Thread: what to do next???
    May 2016
    Cookeville Tn
    17
    what to do next???
    Whew! Just coming off a looooong slam! But, have sparkling water and fairly good numbers: PH 7.4, FC 8.5, CC o, CH 100, TA 50, CYA 50 and salt 2800. I know I should add prod 1 bag salt. My question to you folks is what numbers do I need to work on to keep the pool beautiful. This is what I have done since the slam: letting Cl drop on its on, I have added CYA (about 32ozs), and this am because the CL was at 8.5, I raised the SWG to 30 for generating CL. I reeeealy don't want to let the pool get out of whack, so would appreciate any suggestions from the forum.
    Hi, I am located in Middle TN area, have a 16' x 32' vynal liner, in ground pool and am using a T-9 Hayward Salt Generator system.
    cj3737's Avatar
    Jun 2016
    North Ogden, UT
    629
    Re: what to do next???
    Keep FC at target levels... Check PH to keep it between 7.2 and 7.8. Keep an eye on your TA... It decreases when you add MA for PH control... Other than that it looks good
    Inherited 24' Muskin Above ground
    13500 gal
    Hayward S180T92S Sand filter
    Taylor K-2006C Speedstir
    TFPC for Beginners | Pool Math | Pool School | CYA Chart | SLAM | Test Kits | ABC's
    May 2016
    Cookeville Tn
    17
    Quote Originally Posted by cj3737 View Post
    Thanks so much! I am pretty proud of the clearness of my water...
    A question I have is last year during the season, I had a couple of rust colored spots show up on the liner. I thought when the chemicals were working properly they would prob go away - did not happen. They are still there. I made a pic of one and will attach it, however, it isn't showing up as rust color in the pic. Just wonder if anybody has an idea what might have caused this to happen...
    cj3737's Avatar
    Jun 2016
    North Ogden, UT
    629
    Does it wipe off? I dropped a clamp in my pool one day and forgot about it... was rusted the following day and left a spot but it wiped off
    13500 gal
    May 2016
    Cookeville Tn
    17
    No, it doesn't wipe off and I have a couple of other places that have a spot. I have tried brushing and my granddaughter went down to see if she could rub it off. No luck.
    Jun 2014
    15,110
    If it is a rust-type stain or residue from metal (iron), you could try rubbing the spot with some vitamin C tablets. Place some in a stocking or something, crush them up, and hold it against that area and see if it helps.
