Installed in summer of 2010
Been working fine ever since.
Turn it on this morning and got "fault ign control"
Removed the pool cartridges from the filter and cleaned them (out of habit- always fixed the no flow issue)
Heater fired up.
Later I went back to the equipment and the heater was off, no message on the screen - water was 83 and I had it set for 85.
Turned it off and on and got failure ign control
Did some off and on's and I got a couple "pump failure" messages and a couple "failure ign control".
I cleaned the filters again and it went on again briefly. Then turned off.
This morning the same thing happened. It's clicking on and running for a couple minutes then going off - no screen message.
Or it's clicking on and while it's running I can hear intermittent clicking from inside the heater.
I assume something inside needs to be replaced, but I'm by no means handy to troubleshoot this thing.
Any idea what may be the issue? If it's an easy fix I don't mind doing it.
Heater fired up.
