Thread: Jandy LXi - acting up....
    Installed in summer of 2010
    Been working fine ever since.
    Turn it on this morning and got "fault ign control"
    Removed the pool cartridges from the filter and cleaned them (out of habit- always fixed the no flow issue)
    Heater fired up.
    Later I went back to the equipment and the heater was off, no message on the screen - water was 83 and I had it set for 85.
    Turned it off and on and got failure ign control
    Did some off and on's and I got a couple "pump failure" messages and a couple "failure ign control".
    I cleaned the filters again and it went on again briefly. Then turned off.
    This morning the same thing happened. It's clicking on and running for a couple minutes then going off - no screen message.
    Or it's clicking on and while it's running I can hear intermittent clicking from inside the heater.
    I assume something inside needs to be replaced, but I'm by no means handy to troubleshoot this thing.
    Any idea what may be the issue? If it's an easy fix I don't mind doing it.
    76549 Liters -- Cartridge Filter -- In Ground -- Vinyl -- TF-100 Test Kit -- AquaVac Robotic Cleaner -- UV Sanitation -- Winter Safety Cover -- Installed 2010 -- Southwestern Ontario, Canada
    Latest Test Results June 25:
    FC - 6, CC - 0, CYA - 40, CH - 110, TA - 90, pH - 7.5
    ps0303's Avatar
    Jul 2011
    FL
    3,701
    Re: Jandy LXi - acting up....
    Many possibilities here. When you say you hear clicking inside, I would suggest that you remove the front panel and see if you can pinpoint where it's coming from. Could be the gas valve opening and closing or it could be the ignition control module maybe. Need to see if you can pinpoint where the clicking is coming from.
    Paul
    http://www.gastekservice.com A word of caution: When working with gas and electrical you might want to consider a licensed contractor. Consider the value of your life and others around you. If you would like to provide a review of the help I provided, please use the following link to leave a review. gastek - Google Search,
    Ok,
    Got it going this morning and it's been on for an hour. Seems to be ok.
    However with the intermittent cooperation, there is something not 100% right in there
    I have some company this week, so I'll have to poke around Friday. Maybe I can take a video later when it's fired up to help diagnose the issue.
