Thread: Unconventional pool construction/water circulation
    Jul 2016
    Barcelona, Spain
    14
    Question Unconventional pool construction/water circulation
    So first post here apart from the introduction.
    Reading up on everything pool related i noticed that my pool was built wrong. There is almost no water circulation. Here is what i mean:
    This is the area where my pump is. The arrow points to the only skimmer in the pool and as you can see it's at the same side as the water outlet back into the pool. I guess they did this to save costs on construction. Maybe, or even probably, the large square hole is also a skimmer. That's where the leaf filters are. Everything else except for the sand filter is placed under the wooden cover you see in the top of the image.
    Now, my question is, since i don't have a "proper" water circulation, what is the best way to keep the pool clean? Now, i run the pump 4 hours per day in one morning session of 1 hour, one mid-day session of 2 hours and one evening session of one hour. I try to remember to always set my Dolphin robot to work during the mid-day 2 hours so i have more chance that anything the robot throws around in the water gets caught by the skimmer and passed through the sand filter.
    My pool is pretty clean and my chemical levels are in the proper range from what i can see.
    So i don't have any problems, i am just looking for proper advice considering the unfamiliar build of my pool.
    Cheers,
    Ton.
    25m3, in-ground, home-built (or apparently some french company that didn't know what they were doing), vinyl liner
    Speck Badu 42/9 pump, Zodiac Boreal sand filter, Dolphin Zenit 10 robot
    pH 7.0-7.2, Cl 0.3-0.6mg/l
    cj3737's Avatar
    Jun 2016
    North Ogden, UT
    629
    Re: Unconventional pool construction/water circulation
    If you can install a moveable eyeball onto your return jet you may be able to mess with it and find a good circ pattern. Throw in some wiffleballs to see exactly how its flowing. You robot helps out a little bit but not very much
    Inherited 24' Muskin Above ground
    13500 gal
    Hayward S180T92S Sand filter
    Taylor K-2006C Speedstir
    TFPC for Beginners | Pool Math | Pool School | CYA Chart | SLAM | Test Kits | ABC's
