Thread: Tf100 test kit
    Jun 2016
    Manteo north carolina
    50
    Tf100 test kit
    When I test daily with the tube that you have to match the colors, what should my chlorine be?
    Above ground intex 24x 52 Swg with sand filter pump. Well water. New started the end of May. 11,600 gallons. Test kit TF100
    Jun 2014
    15,103
    Re: Tf100 test kit
    Depends on what your current CYA is. They work together. Please see the Chlorine/CYA Chart (link below in my sig).
    Jul 2014
    Hope Mills, NC
    567
    Re: Tf100 test kit
    That test is just a quick check to see "IF" you have chlorine, it is not a very good indicator of "HOW MUCH" chlorine you actually have. I rarely even use it, but use the pH side all the time.
    16 x 32 17500 gallons
    Vinyl in-ground
    Hayward 250# Sand Filter
    1 HP Pump
    Hayward SWG
